Old 08-12-2011, 10:40 AM
JR Fountain JR Fountain is offline
Default OMNI Preamp issue...
My preamps are having issues. I can barely get any level out of them and I feel like I've tried everything. My mic and cable are both fine (tested on another preamp), I've got phantom power on, I'm selected on mic input, etc. I've got the level jacked all the way to the top and barely anything. I've tried the 2nd pre and it's the same thing. Tried restarting my computer, restarting the OMNI, no dice. What gives? Anybody had this problem?
Thanks,
JR
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 08-14-2011, 12:02 AM
soundboy35 soundboy35 is offline
Default Re: OMNI Preamp issue...
Did you do a reset on the OMNI? Not just power cycling.
Press setup button while PT is not running, turn the rotary knob clockwise until it says RESET. Push in on the rotary knob to confirm.
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Old 08-14-2011, 04:51 AM
Just tried resetting it and it's still behaving the same unfortunately. I noticed another user in the Windows HD Native forum is having the same problem.
J.R. Fountain
Old 08-14-2011, 08:39 AM
formfunction formfunction is offline
Not sure about the Omni, but the 192 has input trims in hardware setup window. Give that a look. ff
Old 08-14-2011, 01:26 PM
akhafaji akhafaji is offline
I don't think we have input trims in HD Omni and I have the same issue and posting my issue in the Native windows froum....
Old 08-14-2011, 01:30 PM
Ya, no input trims on an omni just output trims, thanks though.
J.R. Fountain
Bill Denton Bill Denton is offline
One of those "obvious" things, but did you properly configure I/O in Pro Tools?
Don't know if a failure to do so would give the symptoms you describe, but it's worth looking at...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 08-14-2011, 01:34 PM
Thanks Bill, but tried that too. I usually have the pres available to me in my sessions while I'm cutting so I can record little foley fx as I go. So it's set up properly.
J.R. Fountain
Old 08-15-2011, 08:04 AM
Hi JR
Did you find anything?
Old 08-15-2011, 08:32 AM
Well, if I plug my mic into my external preamp and then feed that into the MIC input of the OMNI I can get a healthy signal, however if I change the OMNI to LINE input (which it ought to be in this scenario) then I get nothing. So while it can pass signal, it's certainly not amplifying the signal properly.
JR
J.R. Fountain
Omni Preamp fix? diamondschwin Pro Tools HDX & HD Native Systems (Mac) 43 08-03-2016 10:01 PM
OMNI Preamp gain stargazer Pro Tools HDX & HD Native Systems (Mac) 4 05-17-2012 12:43 PM
OMNI Preamp gain stargazer Pro Tools TDM Systems (Mac) 3 05-14-2012 02:59 PM
Omni Preamp? DetroitT Pro Tools HDX & HD Native Systems (Mac) 2 01-11-2012 04:58 AM
OMNI preamp impedance? Mr.Scarbee Pro Tools HDX & HD Native Systems (Mac) 0 08-09-2011 04:19 AM
