Old 04-23-2002, 08:23 AM
Chief Technician's Avatar
Default MIX Core, MIX Farm, DSP Farm & G4 933MHz
I'm upgrading from a Beige G3 with a SBS expansion chassis to a G4 933MHz. Is there any possibility that the MIX Core, MIX Farm, or DSP Farm cards will need to be upgraded? Is there any way I can find this out other than moving the cards to the new machine and trying it out?
Any information is greatly appreciated. Thanks!
Old 04-23-2002, 09:10 AM
Rainbow Rainbow is offline
Default Re: MIX Core, MIX Farm, DSP Farm & G4 933MHz
Hi, this is from digis compatibility pages:
DSP Farm and SampleCell II Support:
The PCI Matchmaker chip on a DSP Farm must be rev QC or QE (check the end of the line directly below “PCI Matchmaker” on the chip) to be compatible. Cards with rev Q chips can be upgraded.
<font size="2" face="Verdana, Arial">
Old 04-24-2002, 06:54 AM
DigiTechSupt's Avatar
For all chassis compatibility information for your system, please go here.
Brent
Avid Audio Tech Support
Support FAQ
Old 04-24-2002, 10:02 AM
Brent,
Thanks for the reply, but I now realize that I wasn't clear as to what I'm doing.
My current system is a Beige G3 with a SBS 7 slot expansion chassis.
My new system is a 933MHz G4 [img]images/icons/grin.gif[/img] . The cards for my current system (which reside in the chassis) will soon reside INSIDE the G4. I'm ditching the chassis with the new system.
With that clarified, is there anything I should be checking for other than the PCI Matchmaker chip revision?
Thanks!
Old 04-24-2002, 01:34 PM
AidasZK AidasZK is offline
I did it and didn't hit any problems. Make sure you have a compatible SCSI card though (if you use SCSI drives).
Aidas [img]images/icons/tongue.gif[/img]
Old 04-25-2002, 04:58 AM
<font size="2" face="Verdana, Arial">No, the PCI Matchmaker for any DSP Farm and SampleCell cards is all you need to be concerned with.
-If however, you are currently running PT 5.0 or 5.0.1, I would recommend you upgrading to v5.1.1 (or later) for best compatibility. For all upgrade information, go here.
Brent
Support FAQ
Old 04-25-2002, 06:59 AM
I'm already running 5.1.1, so that won't be a problem. Thanks for the info Brent! [img]images/icons/smile.gif[/img]
Amp Farm / Echo Farm Stop Passing Signal heavymoe Pro Tools TDM Systems (Mac) 3 11-24-2009 09:00 AM
Mix Core, DSP Farm QE, 6.4.1 TdM on 10.3.4 - Farm not shown Table Syrup Records Pro Tools TDM Systems (Mac) 2 06-18-2008 08:00 PM
d24 + mixfarm + dsp farm - losing I/O on mix farm w/64 voic Chris Watkins Digidesign Hardware & Software 3 10-14-2007 09:39 PM
Amp farm 3 ilok auth. "AMP FARM TDM HD"? confirm! crizdee Pro Tools TDM Systems (Mac) 1 11-19-2005 10:06 AM
'Classic' Farm vs. Mix Farm card - both have SRAM? Last Legend Pro Tools TDM Systems (Mac) 1 02-15-2003 04:46 PM
