Old 09-11-2018, 02:58 PM
riozen riozen is offline
Default Digidesign Digi 003 Console Firewire Audio Interface Does Not Link With Mac Pro
My Digidesign Digi 003 Console Firewire Audio Interface Does Not Link With My Mac Pro. I have downloaded and installed PT 11.3.1 to use with my Mac running OS 10.11.6. Everything shows up on the Mac screen and is usable but the link does not connect to the control surface. I have also downloaded and installed the Avid Complete Plug-in Bundle and it shows up on the computer as well.
Avid says they do not support this hardware anymore so I am without anyone to troubleshoot and get this thing going. Any help will be greatly appreciated!
Old 09-11-2018, 03:20 PM
Default Re: Digidesign Digi 003 Console Firewire Audio Interface Does Not Link With Mac Pro
Did you install the 003 drivers?
(are they supported on this OS version... no I'm not going to check).
For starters does the device show up under About This Mac>System Report Firewire devices? If not and an appropriate driver is installed then the most likely cause is a dead 003 Firewire interface chipset.
"Everything shows up blah blah" tells us nothing useful, what *exactly* are you talking about .. does the 003 show up in System Report>Firewire devices? In audio/midi setup? In Pro Tools Setup>Playback Engine? What exact do you mean by "does not Link..."? You mean the interface does not show up as an option in the Playback Engine dialog? Describe exactly what you see happening/not happening.
Do not hot plug/unplug this device that is know to fry the Firewire interface at which point it's likely a large door stop... so the important question is always have you seen this actually working anywhere?
Old 09-11-2018, 04:59 PM
Thanks for getting back to me. Yes, this 003 has made two albums for me over the years. I moved two years ago and have come off the road and I am setting up my studio again.
Did you install the 003 drivers? YES
For starters does the device show up under About This Mac>System Report Firewire devices? YES.
In audio/midi setup? YES
In Pro Tools Setup>Playback Engine? YES
NOW IT IS CONNECTED AND STREAMING!!!!!
Thanks very much for your excellent advice!!!
Old 09-11-2018, 05:08 PM
Great!, but I did not suggest anything that would fix a problem. It could be that you just allowed the computer to sleep/suspend with the interface attached and that will hang the 003 driver until the computer reboots... remember to disable sleep/suspend as a part of optimizing your system for Pro Tools (see Pro Tools Installation Guide).
Digidesign Digi 003 Console Install and setup justus1900 FireWire & USB Audio Interfaces (Win) 3 08-07-2016 04:18 AM
Digidesign Digi 002 Console Windows 7 Issues gwseruset FireWire & USB Audio Interfaces (Win) 9 03-14-2016 10:03 AM
Digi 003 console does not link up to my session Yankeemix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 12-16-2013 03:03 PM
Digidesign Mbox 2 Pro Interface Firewire $99 Shipped joepopp Buy & Sell 0 01-29-2013 09:45 AM
Which FireWire Card for Digi 002 Mixer Console Interface govols1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2012 01:57 AM
