No SPDIF option for Clock Source
Hey,
Is there any reason I'm not getting a spdif option for my Clock Source in my Hardware setup? I'm trying to run my Apogee Rosetta 200 to my MBox 2 Pro via spdif and I only have "internal" as my clock source option. I've tried trashing preferences, rebooting to no avail. Any guidance you can provide would be much appreciated. p.s. I'm running PT 8.0.3 on my macbook pro, os 10.6.3 |
Re: No SPDIF option for Clock Source
Is the Rosetta set for higher than 48K sample rate? I believe the Mbox SPDIF only allows 44.1 and 48K so higher would be seen as an invalid clock.
Unbelievable. That did the trick. Thanks so much for that.
So I can't track anything higher than 48k with my MBox? Does this mean this apogee was a glorious waste of cash? Thanks again, though :) |
I would think the Apogee would actually make more of a difference at the lower sample rates
All MBoxes other than the Pro are capable of 24bit/48k max resolution.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
My problem's solved, so thank you tons. |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
"adat" option not showing in clock source: hardware setup! | Pran | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-02-2007 03:35 PM |
AMS reverts to SPDIF as its default clock source? | gibson_sg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-08-2006 09:35 AM |
help - can't set clock source to adat or spdif | Supermihl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-06-2006 01:52 PM |
PTLE / Mbox forgets Clock Source w/ SPDIF input | dliquori1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-22-2004 05:38 PM |
