Don\'t see my plugins in inserts
Just upgraded to 7.3.1 and I don't see my Sony and Bomb Factory plugs in the RTAS inserts? I see them in the library though.
What happened? Thanks |
Re: Don\'t see my plugins in inserts
I've had the same problem from day one. None of the ignition pack plugins show up on my inserts. I've checked the install path according to the documentation and everything is in the right place. You can even see the plugins loading during the launch of PT. I'm stupmped. Guess I'll try technical support and let you know if they can help. RR
RR Mac Pro OS 10.4.10 2 X 3 GHz Dual Core Intel 4 GB RAM MBOX 2 PT 7.3.1 |
You guys most likely need to download and install the Intel Mac compatible updates for your plugs. I'm just guessing since neither of you listed your system specs as outlined in the "Help Us Help You" thread (which I strongly suggest you read before posting next time), but the most common problem with plug-ins not showing up is that you don't have the right version installed.
Inserts not displaying any plugins | fullscale | macOS | 1 | 08-28-2012 01:51 PM |
Waves plugins won't show up as inserts | eugene-goldberg | Pro Tools 10 | 4 | 02-27-2012 08:07 AM |
projectmix inserts plugins | Cbeaulne | Pro Tools M-Powered (Win) | 0 | 07-31-2011 12:51 AM |
can`t load plugins and hardware inserts. need help | musicmixer04 | Pro Tools TDM Systems (Win) | 0 | 05-11-2009 01:20 PM |
Inserts/Plugins won't work... | bussboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 01-06-2006 09:47 AM |
