Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 08-01-2014, 02:43 PM
David Sandwisch David Sandwisch is offline
Default Re: HDX system and latest NIVIDA graphics cards
Here's a report from Sandra:
SiSoftware Sandra
ID
Host Name : Gary
Workgroup : WORKGROUP
Computer
Model : SuperMicro X8SAX High-End Desktop
Serial Number : 12345*****
Chassis : SuperMicro Desktop
Mainboard : SuperMicro X8SAX
Serial Number : ZM15S*****
BIOS : AMI (OEM) 2.0 09/17/10
Total Memory : 24GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz (4C 8T 3.33GHz, 2.13GHz IMC, 4x 256kB L2, 8MB L3)
Socket/Slot : FC LGA1366
Chipset
Memory Controller : Super Micro Computer X58 I/O Hub 2x 2.4GHz (4.79GHz)
Memory Controller : Intel Core Desktop (Bloomfield) UnCore 2x 2.4GHz (4.79GHz), 3x 8GB DIMM DDR3 1GHz 192-bit
Memory Module(s)
Memory Module : Corsair CMX4GX3M1A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5)
Video System
Monitor/Panel : Samsung SMXL2270
(1920x1080, 21.5")
(1920x1080, 21.5")
Video Adapter : NVIDIA Quadro K600 (1CU 192SP SM5.0 875MHz, 256kB L2, 1GB 1.78GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA Quadro K600 (192SP 1C 875MHz, 256kB L2, 1GB 1.78GHz 128-bit)
Compute Shader Processor : NVIDIA Quadro K600 (192SP 1C 875MHz, 256kB L2, 1GB 1.78GHz 128-bit)
CUDA GP Processor : NVIDIA Quadro K600 (192SP 1C 875MHz, 256kB L2, 1GB 1.78GHz 128-bit)
Storage Devices
Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) : 2TB (E:)
SAMSUNG 470 Series SSD (64GB, SATA300, SSD) : 60GB (C:)
ATAPI iHAS424 B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
AUDIO-VIDEO (E:) : 2TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm)
System Reserved : 100MB (NTFS)
SYSTEM (C:) : 60GB (NTFS) @ SAMSUNG 470 Series SSD (64GB, SATA300, SSD)
Optical Drive (D:) : N/A @ ATAPI iHAS424 B (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Super Micro Computer LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83627DHG
Audio Device : Super Micro Computer HD Audio Controller
Audio Device : nVidia GK107 HDMI Audio Controller
Audio Codec : nVidia GeForce 6800 LE [NV40.2]
Disk Controller : Super Micro Computer 4 port SATA IDE Controller
Disk Controller : Super Micro Computer 2 port SATA IDE Controller
USB Controller 1 : Super Micro Computer USB UHCI Controller #1
USB Controller 2 : Super Micro Computer USB EHCI Controller #1
FireWire/1394 Controller 1 : Super Micro Computer TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : PDFCreator (4000x4000, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : HP LaserJet 6MP (600x600)
Network Services
Network Adapter : Intel(R) 82574L Gigabit Network Connection #2 (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.0
I'm not sure what else to check. The floppy controller is disabled on the motherboard as are all the USB ports but 2. My 2nd Ethernet driver is disabled in device manager as is my 1394 firewire drive (I have no firewire devices). All my device drivers are up to date from what I can tell.
I have experimented with disabling the onboard audio driver and both Ethernet drivers but no change.
Since the HDX card is in the PCIe 2.0 slot and the new Nvidia graphics card has been installed, recording at 48k is more stable. I've been able to consistently do 16 tracks, 24 bit, 48k with a H/W buffer of 256 samples. I'm trying to do 24 tracks now and eventually 32 tracks at 48k.
Still cannot record anything at 96k consistently. It can't even do 1 track at 32 bits, 96k without the 9171 error or now I sometimes get 9129. I thought the 9129 error message said to increase the H/W buffer size but people here think it says to reduce. I will double check if it happens again.
Very frustrating and hard to pinpoint why the HDX system is so touchy.
Ideas I should try or more information I can give here that may be helpful?
Thanks,
David
i7' Graphics Cards ATI/NVIDIA vs Pro Tools Bro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 43 04-10-2012 11:05 PM
Graphics cards tghrs Pro Tools 9 5 12-07-2010 01:49 PM
What graphics cards are you guys using? Big Crouton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 11-09-2010 11:45 AM
Matrox Graphics cards Tomio Broman Pro Tools TDM Systems (Win) 11 02-26-2004 03:37 AM
Graphics Cards and Slowness Baixo Pro Tools TDM Systems (Mac) 3 11-25-2000 12:45 AM
