Old 12-12-2013, 01:27 PM
dfen827 dfen827 is offline
Default Utility for transferring pro tools files into wav or AIFF (outside of Pro Tools)
Does anyone know of a way or a Utility for transferring pro tools files into wav or AIFF (outside of Pro Tools). I'm on a Mac running 10.9 and have some old pro tools files I can't load in my older version of pro tools.
Thanks!
Old 12-12-2013, 01:40 PM
Mark Waters Mark Waters is offline
Default Re: Utility for transferring pro tools files into wav or AIFF (outside of Pro Tools)
The audio files are in the subfolder called "audio files" in the project folder area and should already be in a sound format of some sort. The audio does not get stored in the pro tools project file.. you need the entire directory structure to load the project.
Old 12-12-2013, 02:09 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
I'm assuming you're using PT 11.03 if you are on Mavericks, correct? What version of Pro Tools were these session files created with? Unless the session files are corrupted, you should be able to open them with PT11.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 12-12-2013, 04:50 PM
woodsdenis woodsdenis is offline
Maybe they are SD2 files, do current PT versions support them ? If not will Audacity do it ?
Denis
Mac Pro 3.3 hexacore
24 gb RAM
Lion
PT 10 HD Native
Old 12-12-2013, 06:53 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
I just discovered AmadeusPro has a nice batch converter in it and it can handle SDII files.
Amadeus is a nice editor. Not as fluid as Peak (for my workflow) but very nice for after-PT manipulation.
I will choose,
Freewill
http://jimdiazaudio.com/
Looking for Pro Tools Utility Plugins tbond Windows 11 10-25-2013 12:45 PM
Transferring acid files to Pro Tools spaceman Pro Tools TDM Systems (Mac) 0 08-01-2008 08:01 AM
Will AIFF Files work in Pro Tools? digimike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-16-2006 06:02 AM
HELP! Aiff files unrecognizeable by Pro Tools sfaudiogeek Pro Tools TDM Systems (Mac) 2 12-04-2005 09:21 AM
utility to open and save SDII to aiff or wav?? Lorddiagram General Discussion 2 11-03-2003 07:10 PM
