Old 01-05-2008, 10:25 PM
Smithcok Smithcok is offline
Default Transferring into Pro Tools
Hi
I need to go to another studio to track a band, and they are running Digital Performer. I have an 003R and will be coming back to my place to mix and overdub.
I don't really have the cash right now to blow on DigiTranslator, so is there any semi-easy way of transferring into Pro Tools?
I know one option would be just bouncing all the tracks out, but that would take a long time. Will Pro Tools read the .sd2 or whatever the heck DP records in?
Thanks
www.thestudiofiles.com
Old 01-06-2008, 04:00 AM
Phil Ogden Phil Ogden is offline
Default Re: Transferring into Pro Tools
Just consolidate the DP tracks into full song length files. Or, if there's not too many regions, rename the audio files to incorporate the bar number where it should be placed.
If there's tempo changes, you should export a midi file by way of a tempo map.
Import the midi (if appropriate) and audio into a new PT session and you should be good to go.
PT can handle the DP audio formats including SD2.
http://www.myspace.com/philogg
Old 01-06-2008, 10:26 AM
As far as PT handling sd2's
Once before, while working on a windows-based Pro Tools rig, I tried to drag the files from the DP audio folder into Pro Tools, and they were declared as unreadable by Pro Tools.
Is that just a windows thing?
Old 01-06-2008, 04:05 PM
nedorama nedorama is offline
Your best bet for full file compatability is for your friend to create full-length audio files of each track in AIFF or WAV format, so that each track is the full length. I'd also have him bounce a stereo mix to stereo AIFF or WAV just so you know you're in the ballpark.
You can have him bounce with any effects/eq inserts as well as without.
When you get back home, create a new session, import audio, and import each audio file to the new session. You shouldn't have problems this way.
The method you're talking about (dragging sd2 files into your Pro Tools folder) sounds problematic.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2020.12
Plugins, Virtual Instruments, and real ones
Utility for transferring pro tools files into wav or AIFF (outside of Pro Tools) dfen827 macOS 4 12-12-2013 06:53 PM
Transferring Pro Tools robertocobian macOS 2 09-24-2013 03:48 PM
Help Transferring Pro Tools LE 8 to another Computer halbert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-26-2011 09:47 AM
Transferring Pro Tools to a new computer. PLEASE HELP! NortonRedhouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-25-2010 11:26 AM
Transferring from DP to Pro Tools Paul14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-13-2004 03:32 PM
