Ethernet As Audio input
I may have a far fetched concept. But it may have done before. We use Aviom personal monitoring system through a Yamaha digital mixer. It is audio source is connected with Cat 5 cables daisy chained and using a personal mixer for each musicians. The mixer I assume is doing some-kind of Digital to Analogue conversion.,
Now if you connect a "raw" Cat 5 cable to Mac will it understand it as a audio data natively. Say if you launch ProTools, will it understand the audio signal without as audio interface. I assume it will rely on operating system. May be I am not stretching too far..
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49 |
Re: Ethernet As Audio input
Pro Tools would need to have an option to select one of the two (or other ports if have added them via PCIe) Ethernet ports as an input source...or basically as the "interface". And that option does not exist to my knowledge.
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM 970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions) HD5770 GPU OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+ Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76 |
Things like Dante virtual soundcard do this job for the Dante protocol. Aviom uses their own protocol (A-Net). Aviom do make a bridge for Aviom to Dante but it is a distributor only (it takes the input from the Aviom and sends output via Dante.) So with that bridge and the Dante Virtual Soundcard, you could receive audio from the Aviom into Pro Tools direct. But you could not send audio from Pro Tools to the Aviom.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Yeah, it is all about protocols. Dante, Ethersound, AVB, CobraNet, Soundgrid, etc all function over cat5 ethernet connections. If your plan is to connect the Yamaha mixer to your MacBook, then it is probably best to insert a Dante card in it. This will work with your mac's ethernet port when you install the Dante Virtual Soundcard driver.
I have no idea if they play nicely together, but a lot of the yamaha desks have more than one card slot. It may well be possible to run the A-Net card for the Aviom system and the Dante card side by side. It might be worth researching.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
M-Audio Fast Track Ultra fisical input 1 appears in VST input 2 | blackpauldays | FireWire & USB Audio Interfaces (Win) | 0 | 07-19-2016 08:43 AM |
using HDMI input mutes line audio input of TV | mr.armadillo | Post - Surround - Video | 15 | 09-24-2013 12:33 AM |
Audio over ethernet plug? | ampnerd | Pro Tools TDM Systems (Mac) | 5 | 10-30-2010 09:49 AM |
Ethernet and audio wiring(behind the wall) info | Armando | Pro Tools TDM Systems (Mac) | 0 | 10-27-2005 01:50 AM |
IS ethernet reliable for audio transfer ? | andre tchmil | Pro Tools TDM Systems (Mac) | 14 | 12-01-2002 05:31 PM |
