PT11 + Reason Rewire Constantly Overloads CPU??
Im currently trying to rewire Reason 7 into PT11 and can't even get a few seconds before i get a CPU overload (6101 error) Doesn't matter even if i have one track only in Reason. Buffer size is at its fullest and my Macbook Pro is definitely capable power wise (i7 2.6ghz 16gb ram). Back in the day I could rewire huge sessions into my old white macbook and have no problems at all.. Any idea whats going on?
Re: PT11 + Reason Rewire Constantly Overloads CPU??
i7 2.6ghz 16gb Mac Mini.
11.0.3 regular OS 10.9.2 RSN 7.0.1 002 interface (003 drivers) External Audio Drive (SSD) Boot Drive (SSD) 32, 128 & 1024 buffers working fine here. Did reason get setup in standalone?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
I assume you mean "standalone" as in it didn't get rewired as a slave to pro tools? Both are running at 64 bit and reason is slaved
I recently encountered a problem with Reason 7 and PT11. Not quite the same as you describe - in my case, distorted playback from Reason - but perhaps related? I finally figured out that if the Buffer setting in Reason's prefs isn't the same as buffer setting in PT, then playback from Reason will be distorted. Obviously a bug.
Now when I instantiate Reason as plugin, after Reason boots up - before I hit play - I go into Reason prefs and set the buffer to match PT's. It may or may not be relevant to your issue... Good luck!
Current system: MacPro (Late 2013) 3.5 GHz 6 Core, 32 GB RAM OSX 10.12.5 Pro Tools 12.8 Apogee Duet 2 Glyph Drives + Blackmagic dock with Samsung SSDs Reason 10, Ivory II, BFD3, Finale Plugins: Kush, Kontakt, Komplete Ultimate, Exponential Audio, Waves, Slate, Fab Filter, TDR, Pultec Bundle, Bomb Factory, UVI Workstation, Sonnox, Soundtoys, Massey, Valhalla, Aether, PhoenixVerb, etc... also 17" MacBook Pro w Core i7, OSX 10.9.4 |
Any updates to this issue? Maybe its a different issue
I have PT 11 HD and running on a Mac Pro Westmere, 32 gigs of ram, all SS drives. Protools can run 64 buffer with tons of tracks and plugins fine. Very low CPU. When I create a simple 4 track no plug in project. CPU is super low. Load rewire to Abelton and the main cpu spikes to red a lot and cannot run buffers under 256. Seems like a rewire plug in issue or something. Needs to be fixed as it makes rewire useless. Going into 256 buffers I can already tell latency with Abelton and pro tools compare click track. I hope someone has a solution for his very soon! |
PT11 AAE Error -20010 Ableton 9 (x64) Rewire? | defyurself | macOS | 10 | 09-15-2016 03:11 PM |
AAE - 9173 cpu overloads in pt11 vs pt10 | Carbon 2501 | Pro Tools 11 | 0 | 03-07-2014 09:22 PM |
PT11/Reaper Rewire workflow? | crandallwarren | Virtual Instruments | 3 | 02-19-2014 11:50 AM |
Reason 6.5.3 Overloads CPU in PT | [email protected] | Pro Tools HDX & HD Native Systems (Mac) | 5 | 06-09-2013 12:04 PM |
reason 2.5 rewire | guypople | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-21-2005 05:54 AM |
