Distortion - lower headroom.
Hi
I am getting distortion when My levels are around 0 db on the master meter Nothing is hitting red. Levels used to go up to +6 without distorting. I have tried a session with just an instrument track with xpand2 piano and a master track, and it is the same thing. Digitest shows no errors on cards Trash Prefs done I have moved my cards between old and new systems a few times due to update from 7.3.1 on late G5 PPC to current Mac Pro 1.1. 8.1.1.1. Afraid I might have damaged the cards somehow. I can work around it, using lower levels, but now I am constantly worrying that something is distorting somewhere. Please help Thanks box PT HD2 PCIE 8.1.1.1 192 IO Mac Pro 1.1 10.6.8 |
Re: Distortion - lower headroom.
Unless you are mastering, you really shouldn't be very close to 0 dBFS.
In the digital world, 0 dBFS on a meter is where digital distortion begins (it may vary a tiny bit on different meters). While the recommended numbers vary among different engineers, I use what I have found to be the levels recommended by a lot of engineers I respect... When tracking, average levels should be around -15 to -18 dBFS. When mixing, peak levels should be around -3 to -6 dBFS. When mastering, peak levels must not exceed 0 dBFS. Hope this helps...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Yes, maybe I should clarify.
In Pro Tools 8 The scale on the master bus level meter goes from -Infinity to +6 db. 0 dBFS lies somewhere above this, so the scale is only showing comprehensive dB levels inside PT, and really doesn't show where 0 dBFS is. My frustration is, that I used to be able to having the levels between 0 and +6 dB on the (fake) meter when I used a mastering plugin, and now I don't anymore. I am wondering what has happened Thanks -Box |
0 dBFS (dB Full Scale) is always at the very top of the meter where it clips.
PT8 introduced the new GUI where green goes yellow at -15dBFS and it should be considered "the new red" when tracking. Use pre-fader metering and with all plugins bypassed, do not let your levels climb over green. When mixing, your master as a rule of thumb should never go above -6dBFS because less-than-perfect DA converters don't work linear "at the last bit". Leave that hitting-the-roof magic for a skilled mastering engineer, please.
Thanks for the replies so far.
I know what you are all saying, and I usually don't hit the master fader very hard when I am mixing. Sessions that didn't use to distort, suddenly do. I have even experienced the distortion when playing professionally mastered material in Roxio Toast playing through the 192. Never used to distort, now it does. I just wondered why I suddenly got a lower headroom than I am used to. Why the change? Thanks -Box |
Just bouncing this one...
Have just listened to a mastered track in iTunes, playing through the 192. Once the song gets going, things are really distorting... When I import the track into Pro Tools, it also distorts. Trimming the input on the track down -6, it no longer distorts. Can I do some kind of test that will show if either my HD cards or my 192 has gone bad? I mean... I should be able to listen to red book mastered music in iTunes through the 192. Thanks -Box |
Headroom... | armytanker | Pro Tools 10 | 16 | 01-07-2015 05:11 AM |
What is "Headroom" | er1c | Tips & Tricks | 7 | 10-16-2005 01:41 AM |
Headroom??? | scottedog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-08-2004 01:44 AM |
There is NO headroom beyond 0.0! | John Link | General Discussion | 11 | 07-16-2002 07:05 PM |
SD II headroom | ebergallo | Digidesign Hardware & Software | 1 | 07-26-1998 04:53 PM |
