Old 05-20-2004, 11:45 PM
milet22 milet22 is offline
Default Protools LE 6.1.1 freezes on startup
Howdy,
I just got an Mbox and was really excited to use it. I followed the installation instructions exactly and even updated the Mbox firmware as requested. When I try to start Protools, however, the system freezes; I've tried leaving it for a few minutes and still nothing happens.
I've tried uninstalling and reinstalling, but I still have the same result. I tried looking through the online support and the forum here, but I found nothing. I appreciate any and all help.
Thanks
Rob
PS I'm running WinXP (SP1) on an AMD 2500+ with 512 MB of RAM if that helps.
Old 05-20-2004, 11:57 PM
nic copenhagen nic copenhagen is offline
Default Re: Protools LE 6.1.1 freezes on startup
my friend just had this problem. check to see of your motherboard is compatible with PT, otherwise, you might have to change your set up.
Old 05-21-2004, 12:07 AM
The mobo doesn't seem to be the problem. I am using an Abit NF7-S which has an NForce2 chipset. There is nothing on the compatibility page that suggests this would cause a problem.
Rob
Old 05-21-2004, 12:47 AM
Update: I installed the 6.4 upgrade and it still doesn't work. It no longer freezes, but now I get the blue screen of death on PT startup.
Again, any and all help is appreciated as I'm getting frustrated :/
Thanks
Rob
Old 05-21-2004, 05:39 AM
spkguitar's Avatar
What was the message on the B.S.o.D?
Have you tried disabling the onboard audio?
What other peripherals do you have installed? (which brand video card, which brand hard drive, any other cards, etc etc)
Old 05-21-2004, 12:23 PM
The BSOD says "Windows has detected a problem and shutdown to prevent damage to your computer." It quickly reboots the system so the rest is had to read.
I tried disabling the onboard audio, and I still get the same result.
Here's the rest of my system
CPU: AMD XP 2500+
Memory: 512 MB RAM
Mobo: Abit NFS-7
Video: ATI Radeon 9700 Pro
Sound:
Creative Live MP3 (I use the motherboard's onboard audio, but I kept this card for its midi connection)
HD:
120 GB SE Western Digital (sata)
100 GB SE Western Digital (ide)
40 GB Maxtor (ide)
CD/DVD:
Plextor CD-R (ide)
Creative DVD (ide)
Linksys Wireless-G card
ATI TV Wonder card
Thanks
Rob
Old 05-21-2004, 12:36 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Remove the SB Live - its been known to be incompatible with PT on many systems.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 05-21-2004, 12:49 PM
I took out the SB Live and still BSOD...
Thanks
Rob
Old 05-21-2004, 04:12 PM
Cliffy_Boy's Avatar
You may also need to do the following to properly uninstall PT.
1- also locate and remove dalwdm.sys
2-remove Quicktime
3 from the readme:
In order to maintain Avid compatibility (for example, with Avid Xpress DV), the following files are not removed when uninstalling
Pro Tools 6.4: Keyfilter.dll, Winmmfix.dll, dsi.dll, and directio. If you need to revert to an earlier version of Pro
Tools, you will need to manually remove these files before installing.
When you reinstall, also install Apple Quicktime.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 05-22-2004, 12:06 PM
Default Re: Protools LE 6.1.1 freezes on startup/6.4 BSOD
First, I want to thank everyone who has offered suggestions; I appreciate it.
I tried uninstalling and deleting those files you mentioned and removing QT, but I still have the same BSOD.
I called Digi tech support, and the tech support guy Virgil was very patient and understanding, but never called me back as he said he would. After defragging/checking my drive, I tried taking all the cards out of the computer except video, taking out all the drives except a single IDE HD, disabling everything onboard the mobo (incl. sata), and disabling every startup services/program except the PT ones--same BSOD.
I'm really frustrated here. I was extremely excited to purchase the Mbox and PT, but I'm almost to the point of taking it back. I splurged to buy it, but I can't afford to pay $1000 to throw together a new computer JUST to run PT. Admittedly I new to this so maybe I'll get flamed, but I don't think it's fair that a user should have to buy a new computer just to run the program; I completly understand there are "optimum" configurations, but I have a decent setup that meets all the compatibility requirements listed on the box. If the software is that finicky, the box should be explicit as to what is required.
Sorry to rant, I'm just frustrated. If any kind souls have any more thoughts or suggestions, I would really appreciate it.
Thanks
Rob
ProTools LE8 freezes after DAE loaded in startup audiophile2010 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-29-2010 07:26 AM
Pro-Tools 8 Just Freezes on StartUp Limn Pro Tools M-Powered (Win) 1 08-24-2009 03:39 PM
PT 6.4 freezes after startup logandrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-06-2005 10:39 PM
PT Dae freezes on startup Bossi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-23-2005 12:35 PM
PT freezes on startup rastro2 Pro Tools TDM Systems (Mac) 3 07-26-2002 06:39 AM
