Old 01-16-2012, 06:40 AM
conleec conleec is offline
Exclamation BUG: All Clips in Edit Window Disappear!
Yesterday, after working on a 20 minute audio to picture mix for several weeks without issue (except for the randomly disappearing outputs issue, which has been well documented) I was nudging a single sound effect into sync and suddenly ALL the clips on my timeline vanished. Gone. POOF! Well, except for the single clip I was nudging; it was still there.
I assumed this was a redraw error of some sort, but no audio would play and no meters would move if I moved into the empty region and pressed play. Well, needless to say, this scared the heck out of me, so I saved as a new name and closed out and reopened the session.
Well, the worst happened. When I reopened the "corrupted" session, it was in fact still empty, which REALLY scared the heck out of me. Thankfully I had saved with a new name, so I reopened the earlier version and redid my work.
Unfortunately, it now seems this session has a creeping issue, because it happened to me several more times throughout the day. Not good. It seems similar to this MIDI issue in another thread, but in their case, a save and reopen will resurrect their session. In my case, a saved version will reopen with the clips still missing.
http://duc.avid.com/showthread.php?t=314955
Has anybody else seen this? Any suggestions?
Chris
Old 01-16-2012, 08:06 AM
EGS's Avatar
EGS EGS is offline
Default Re: BUG: All Clips in Edit Window Disappear!
Originally Posted by conleec View Post
...suggestions?...
Create a new blank session (same sample rate) and import session data form corrupted session. Hope this helps !!!
Desktop: PT 2019.6 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook 4730s / i7-2630 / 8GB / U-PHORIA UMC1820
Info/Services link
Old 01-16-2012, 10:39 AM
Thanks EGS. Will try that when I get back to my studio. It's kinda scary, though.
Chris
Old 01-17-2012, 10:13 AM
I'm working away from my office and still haven't had a chance to get back to this side project. But just wondering if anybody else has seen this behavior?
Chris
Locked - Cannot use selection tool anywhere in edit window or move clips! eneedham macOS 30 05-05-2012 08:23 PM
Losing ability to select clips in Edit window kheftel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-06-2009 12:23 PM
Cannot change EDIT MODE in edit window Xavior Pro Tools M-Powered (Mac) 2 05-24-2007 12:51 AM
Notes disappear when I try to edit Them! Hardnox Tips & Tricks 7 02-25-2007 11:27 AM
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-08-2006 10:49 PM
