Go Back   Avid Pro Audio Community > Announcements > General Announcements
Old 07-05-2006, 07:00 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools LE & M-Powered 7.1.1cs1 Updates
For Intel-based Macs only.
Available from the Pro Tools LE and M-Powered 7.1.1 Intel Mac Download and Answerbase sections in Support.
Pro Tools LE 7.1.1cs1 Download:
http://www.digidesign.com/index.cfm?...4&itemid=23146
Pro Tools LE 7.1.1cs1 for Intel-based Macs contains the following:
Fixed: Pro Tools Always Overwrites Automation in Existing Playlists When Using "Import (Session Data) - Overlay New on Existing Playlists." (Item # 63172)
• Pro Tools would not allow a session with a 2-hour start time to overlay automation data on a session with a 1-hour start time without clearing all automation before 2 hours on the destination session.
• Automation cannot be "combined" with an overlay - the destination session's automation will be replaced from the Session Start time of the source session.
• Inserts and sends must be consistent between sessions or they may be overwritten.
Fixed: Volumes With Japanese Naming Will Not Mount In DigiBase. (Item # 73463)
• Volumes with Japanese naming will not mount in DigiBase and will not allow you to create a Pro Tools session without an error.
Fixed: Opening or Importing an OMF With AIFF Media Would Result In An Error (Item # 77908)
• This would result in an assertion error.
• DigiTranslator users only.
Fixed: When Using CoreAudio Input To Record With Third Party Applications, Digital Noise Would Result. (Item # 78481)
• Note that this problem only occurs with Intel-based Macs.
Fixed: Some Automation Moves Could Be Written Incorrectly When Writing Immediately After A "Play" Command (Item # 78032)
• This could occur when touching a control immediately after a "play" command, but before the transport started moving.
Who Should Use Pro Tools LE 7.1.1cs1?
This update is recommended for all Pro Tools LE 7.1.1 for Intel-based Mac users and contains fixes in the following areas:
• Using "Overlay" with "Import Session Data"
• Using volumes with Japanese naming
• Importing OMF Files with AIFF Media
• Using CoreAudio to record with third party applications
• Writing Automation
Pro Tools M-Powered 7.1.1cs1 Download:
http://www.digidesign.com/index.cfm?...4&itemid=23148
Pro Tools M-Powered 7.1.1cs1 for Intel-based Macs contains the following:
Who Should Use Pro Tools M-Powered 7.1.1cs1?
This update is recommended for all Pro Tools M-Powered 7.1.1 for Intel-based Mac users and contains fixes in the following areas:
Administrator
HTML code is On
Pro Tools 8.0.1cs1 Updates Available Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-12-2009 03:12 AM
Pro Tools 8.0.1cs1 Updates Available Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-12-2009 03:11 AM
Pro Tools 8.0.1cs1 Updates Available Avid Pro Tools TDM Systems (Win) 0 11-12-2009 03:10 AM
Pro Tools LE & M-Powered 7.1.1cs1 Updates Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 09-21-2006 10:35 PM
Pro Tools M-Powered & LE 7.1.1cs1 Updates Avid Pro Tools M-Powered (Mac) 0 07-05-2006 07:05 PM
