Old 04-13-2011, 02:29 PM
shoe124 shoe124 is offline
Default shortcut to get window to pop up while using PT?
The Apple + "=" key will rotate thru the mix and the edit windows. Is there a shortcut while operating PT that will pull up the editor window for Eleven?
I always end up putting it somewhere, then it is in my way while tracking and editing...
Any suggestions would be great!
Thanks
todd
Old 04-13-2011, 03:02 PM
madgt621 madgt621 is offline
Location: Current: Ikebukuro, Tokyo, Hails from: San Francisco
Default Re: shortcut to get window to pop up while using PT?
On a Mac, you can create your own keyboard shortcuts, per application. the process differs depending on your on which version of OSX you are on, but I believe this is how you do it in Snow Leopard.
Open your "System Preferences" and select "Keyboard"
Then select "Keyboard Shortcuts" and then select "Application Shortcuts"
You then want to click the little "+" sign to create a new shortcut.
When the new shortcut box appears, click the "Application" area and select "other"
A new finder window will pop up. Go enter the "Digidesign" folder in the "Applications" folder, select "Pro Tools", and click "Add" (Note: "Pro Tools" as an application may already be in the list that pops up. If it does, just click that, and not "other")
In the "menu title" area, type in "Eleven Rack" w/o quotations. It's important that the title is the EXACT command in the program's menu.
After that, type in your desired shortcut in the "Keyboard Shortcut" menu, click "Add" and that's it!
You can always delete the shortcut by selecting it, and click the "-" as opposed to the "+".
Hope this helps.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Old 04-13-2011, 05:41 PM
Benoni's Avatar
Benoni Benoni is offline
You can also turn on/off the Full Eleven Rack window (as well as make other adjustments) in the Eleven Rack Mini Window located at the top of the Edit Window.
Shortcut for Scrolling Mix Window? taylor4814 Pro Tools 10 6 02-09-2012 11:38 AM
Movie window shortcut?? drBill Pro Tools TDM Systems (Mac) 4 01-12-2005 05:33 PM
Window Sizing shortcut ? Ian Fish Pro Tools TDM Systems (Win) 2 08-27-2004 02:50 PM
close audiosuite window shortcut? lancebrwn Pro Tools TDM Systems (Mac) 0 06-27-2004 01:47 PM
Mix to Edit window shortcut Cliffy_Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-29-2003 08:45 PM
