Multi Mono Or Stereo?
I'm not sure if this has been covered or answered before but, I noticed that the New EQ for Digi is a mono and multi mono plugin and not a just stereo plugin. Usually when you put a plugin in multi mono it takes up more processing as if your using two plugins. Is there any benefit to using multi mono plugins? Does it sound better, bigger, more width?
If not, why didn't digi make it into a stereo plugin? Thanx M2E
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies) YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc |
Re: Multi Mono Or Stereo?
Multi mono enables you to make seperate adjustments for left and right! other than that there's no difference. click on the L icon to access the right channel! and click on the stereo icon next to it to switch stero link on/off Regards Chris
Multi-Mono Trim Plug-In on Stereo Track? | Napping | Pro Tools 10 | 1 | 02-06-2012 08:48 AM |
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin | JesseF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-14-2010 09:01 AM |
Stereo Interleaved vs Multi Mono | studiojimi | Pro Tools TDM Systems (Mac) | 17 | 12-08-2009 11:20 PM |
mono to multi mono or stereo? | Dean Smith | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-21-2006 02:32 PM |
multi mono/stereo inserts | corTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-02-2004 12:11 PM |
