PT 12 blinking play button/solid stop
I've started getting the blinking play button and solid blue stop issue since Pro Tools 12.6, and 12.6.1 is doing the same. I've read through several of the threads and when I try to change my Buffer Settings it completely freezes Pro Tools (I may not be waiting long enough, but it is over 1 or 2 minutes that Pro Tools stops responding).
The sad thing is, it works fine for a while on a new project, but when I have my project nearly finished, save it, and then try opening it up the next day, it does this almost every time. I have been able to somewhat recover the project file if I change the hardware buffer size and then power off the MBOX Pro 3. Pro Tools will ask if I want to quit or save, and if I choose save it will save a new PTX file that will open I don't know if it's the MBOX Pro 3, or Pro Tools 12.6.X, or if it's Vienna Ensemble Pro which I also use. But the issue is pointing more towards 12.6 and the MBOX. I also have made sure the Dynamic Processing is not enabled on the Play button. I have had a click track, and also have it count off 3 bars (which sounds like it might also contribute to the issue). My HW settings are usually either 512 or 1024. This particular project is at 512. I also use the "Normal" value for Cache. I don't know if buying a different audio interface will be helpful or not? It's not that I hope to buy a new interface, but this is just getting worse and worse, and fixing project files rather than recording/composing is becoming tedious. My specs are: Intel Core i7 2600 16 GB RAM MBOX Pro 3 Firewire Windows 10 Pro 64-Bit 3 x 1 TB Samsung Evo Pro SSD Last edited by rmoat; 12-06-2016 at 08:47 PM. |
Re: PT 12 blinking play button/solid stop
http://www.pro-tools-expert.com/home...ack-modes.html a little strange if it is doing this all the time .. do you have any peripherals attached to your system and selected ??
Hi John,
I also meant to mention that I made sure that "Prime for Playback" was not checked either. The only thing I have checked is "Loop". It seems like it only started recently since PT 12.6 came out. I don't have any peripherals other than the regular necessary hardware plugged in (iLok, Vienna Key, USB MIDI Keyboard) |
I figured I can get past this issue by doing the following:
1. Change HW buffer to different setting (1024, if I'm using 512, or vice-versa). 2. Let Pro Tools sit there frozen for several minutes 2 - 5 minutes 3. Finally unfreezes, and then I can switch it back to the HW buffer I had it at and it plays I noticed that when this happens though, when I save the PTX file again, it is very huge. It jumps from 2 - 4 MB to 40 MB. Not really sure what it's saving in that file during these issues. |
Hi rmoat !
Try trashing databases and preferences first if not yet . If that fail try a clean reinstall of PT.
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Did you accidentally enable "Wait for Midi Note"?
jeam25 - I have trashed the preferences several times. I have not tried a complete uninstall/reinstall, so maybe I'll need to look into that.
albee1952 - "Wait for Midi Note" is not enabled. Also "Prime for Playback" is also not enabled. I mentioned this to our audio department at work, and they think it's the old MBOX Pro 3 drivers (Windows) and issues w/ PT 12.6.X. I think they have a 003 that is doing the same as mine. No problems with the MOTU interfaces that they use (though I think those who use the MOTU interfaces are still on PT 12.5). So it isn't conclusive or anything, it's just a guess... |
Or accidentally put it "online?" (Alt-spacebar on Windows, then the blue clock flashes.) Since ALT is right next to the spacebar, it's easy to accidentally do that a few times a day.
I'll check this tonight, but I doubt it's in online mode due to that fact that it starts working again after changing the HW buffer (Normally if I'm lucky, though sometimes it requires a reboot after changing the HW buffer size).
Hi rmoat !
How are you doing on this ?! Its resolved ?
Music won't play. Play button flashes and Stop button lights up | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 04-16-2020 03:03 PM |
Blinking STOP/PLAY transport buttons PLAYBACK ISSUE | guitarman6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 08-14-2019 12:26 PM |
Stop button lighted,play button blinking not playing | RichrdC | Pro Tools 11 | 6 | 11-05-2016 05:48 PM |
The blinking stop button problem | Benji575 | Windows | 12 | 01-29-2013 03:21 AM |
When press play the stop key lite and play key blinking | Sam Yin | Tips & Tricks | 6 | 12-05-2009 08:26 PM |
