Old 04-04-2018, 09:57 PM
mihumusic mihumusic is offline
Default PT 12 HDX + digi pre compatibility
does anyone know if the old digidesign pres are compatible with Pro tools 12 HDX set up or do i have to buy the newer avid pres?
thanks
Old 04-05-2018, 07:41 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: PT 12 HDX + digi pre compatibility
Mic preamps. To be clear not an interface.
You'll need a MIDI I/O (Any Brand) if you plan on using ProTools Soft Remote.
Should work fine keeping the above in mind.
Old 04-05-2018, 09:40 AM
great, thank you!
Old 04-05-2018, 11:26 AM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by DetroitT View Post
You'll need MIDI I/O if you plan on using ProTools Soft Remote.
...which is also discontinued and unsupported?
Janne
Old 04-05-2018, 11:27 AM
from my research, it seems to work with any midi interface, not jus the discontinued digi one so I should be good there.
Old 04-05-2018, 12:28 PM
BScout BScout is offline
Yes, any midi interface will work. We use the MOTU microlite.
Old 04-05-2018, 09:00 PM
Samanthas Dream Samanthas Dream is offline
Yep,working fine for the last 10 years with a generic MIDI interface.
15 years as PTHD User, Protools 2018 Ultimate, 24 Channel iCon D-Command, Avid Omni, Lynx Aurora 16, (2) BLA Modified 192 I/O’s, DigiPre, Way Too Many Outboard Compressors/EQ’s/ETC, where did all my money go????
Digi G5 2.5 Compatibility- When?? Armando Pro Tools TDM Systems (Mac) 3 08-20-2004 11:31 PM
win xp compatibility with digi 002 mirok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-20-2004 09:32 AM
HD (5.3) compatibility with LE (5.1.1-Digi 001) dphenzer General Discussion 2 01-14-2003 06:33 PM
HD (5.3) compatibility with LE (5.1.1-Digi 001) dphenzer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-13-2003 08:44 AM
For Digi: Compatibility with OS 9.2.1 newdawg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-30-2001 10:31 AM
