Old 03-28-2006, 09:29 PM
Stompinmsc Stompinmsc is offline
Default PT 7.1 System Freeze after DAE Loaded
Everytime I try to run PT7.1 the load window stops at DAE Loaded with what looks like 5-6 bars to go and just hangs forever.......What is going on? Anyone? Can't run PT on my Windows machine at the moment....Any help?
Rob
Old 03-28-2006, 09:54 PM
gwell1 gwell1 is offline
Default Re: PT 7.1 System Freeze after DAE Loaded
hey man i'm having the same problem! I dont know whats going on. I tried installing 6.9, and thats doing the same thing. I have to re-install pro tools. But once its re installed, it will load fine for about 3 to 4 for times, then start that freezing stuff.
Old 03-29-2006, 12:08 PM
It is wierd, I can't figure it out... My system was running fine for months then it just started happening.
3.0 Dual Core - Asus MB - 2gig ram
Rob
Rob
Old 03-30-2006, 10:57 AM
mhayes mhayes is offline
Well I was going to copy paste what I just posted for gwell1's original post... but you're running one hell of a beautiful system... so I really have no clue. Try posting in the PT TDM Systems section of the DUC, I'm sure someone there could help you out more... sowwy...
Mike
Old 03-30-2006, 11:48 AM
Try running Pro Tools under a different user account... What happens?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-31-2006, 02:52 AM
I only have my one account...Still nothing today......Good thing my HD Rig never has an issue.
Rob
Old 03-31-2006, 06:50 AM
WilliamDC WilliamDC is offline
I had this problem and it was the driver for the firewire card that comes with Winxp SP2. I reverted to the driver from SP1 and the problem went away.
William
002R - 2ghz Intel Core 2 duo Imac - 3GB of RAM
OSX 10.6.7 - PT LE 8.0.5
http://www.pureshift.com
http://www.bsodmusic.com
Old 04-03-2006, 11:46 AM
I am running it usb with the MBox 2. I tried the Asio driver in Sound Forge and it just freezes, so I am thinking it is the audio driver. Deleted and reloaded several times to no avail...
Rob
Old 04-11-2006, 12:22 PM
Kevin Taylor Kevin Taylor is offline
Had the same problem. Everything worked fine until I upgraded. I ended up changing what Firewire drive I load my 002 into and it fixed it. If you don't have a PT recommended firewire card, this will most likely solve your problem. One thing you can do in the meantime is turn on your 002 prior to turning on your computer. I did that for months and it worked fine, but if I turned the computer on first, then the 002...I got that hangup problem. Now that I'm in a different firewire port...I'm good to go regardless...
003 DAE Loaded Freeze chasebasolo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-04-2011 02:05 PM
Windows Vista 64 DAE Loaded Freeze Danstaddon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-01-2008 05:00 PM
DAE loaded freeze mjones976 Pro Tools M-Powered (Win) 6 08-18-2008 08:37 AM
Aniticpated Plugin Count for Loaded 002R System GenerationM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2005 01:40 PM
HD2 Freeze on "DAE loaded" capsound Tips & Tricks 0 05-30-2004 02:30 AM
