Please help!!! 9600 won\'t start!
Yesterday I was installing some new ram in my 9600, and when I tried to power it up, it wouldn't start up at all...even after I uninstalled the ram, same thing. Does anyone have any suggestions? Is there a fuse or breaker I should know about? Thanks!
Re: Please help!!! 9600 won\'t start!
unplug the Machine..then try again.
If it doesn't do anything at all, even when pushing the green button on the front... no noise, green light, click, nothing, it's probably the power supply. If it starts but you have a black screen, try the pram (option/apple/p/r while booting), restart a few times with ctrl/apple/start button, reset the cuda with the little red button inside the CPU
It doesn't do anything at all, as opposed to coming on and giving me a black screen. I tried unplugging it, and that didn't do anything...where is the little red button located? Thanks!
Reset the mother board..
Theres a little silver button near the power supply on the MB unplug the machine , hold down the button for 30 sec. this will flush all your system wide settings, so make sure you reset all system setting when it comes back up ie... Memeory Control Panels... hope this helps |
Make sure all the cards are seated and have not come loose.. Check the processor card and the ram by pushing them down.. Also try removing and reseating them.. Be careful not to touch the conductive areas or components and discharge your body "Static Electricity" before touching the cards. You may also try reseating any connectors and check the power cord in the back of the computer.. I know some one last week that ran into the last that one, the plug was in but not seated.
Mac Pro: 3,1, 8 core, 6GB RAM. OS 10.6.8, Protools 10.3.8 TDM HD2 Accel. |
Seems obvious, but check the power chord. Is it plugged into the computer all the way? Is there power coming from the wall? Sorry to state the obvious, but this has got me before. [img]images/icons/smile.gif[/img]
Karen Basset Boom Chic Studios Los Angeles, CA 90048 [email protected] http://www.boomchic.com |
I couldn't find a silver button, but I did find a little red one next to the processor, and after holding it down for thirty seconds with the computer unplugged, I'm up and running. Thanks again for the help everyone!
Now, if I could figure out how to get this second scsi drive to work..... |
Downloaded PT 8 and it wont start PT logo moves but doesnt start????????? | protonneutron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-30-2008 03:25 PM |
Can you put a stock 9600/350 processor in a 9600/200? | ragbor | Pro Tools TDM Systems (Mac) | 4 | 06-14-2001 10:29 AM |
Pro Tools 5.1 Session Start—Record Start Interval | Avid | Pro Tools TDM Systems (Mac) | 4 | 04-18-2001 08:27 AM |
So you have a G4 OS 9 install disc and a 9600, HTF, Do you get the OS on the 9600... | editor | General Discussion | 18 | 02-14-2001 12:47 AM |
PPC 9600/200 vs 9600/300or350 with xlr8 G3/333? | cander | Pro Tools TDM Systems (Mac) | 6 | 03-01-2000 02:31 PM |
