Will my rig run PT2019?
I'm just wondering if anyone else who has my setup is running 2019? I know requirements are padded for safety reasons and often they say it won't run when others are in fact, running it successfully.
I have a mid 2012 MacPro 5,1, with 12 cores 2x2.4 6 cores each, running High Sierra 10.13.4 and am easily running PT 12.8.3HD on an HDX card and HD I/O 8x8x8 with an ATI Radeon HD5770 w/1024mhz card. 32 gigs of memory. I guess I need Mojave as well so wonder if that will run also. Would appreciate hearing from any users who might be running PT19 with a similar setup. Thanks. |
Re: Will my rig run PT2019?
A) You don't need Mojave. And with the 5770 graphics card, it might be a bad idea anyway
B) You should update your High Sierra to 10.13.6 (last version of High Sierra) through the App Store C) Yes, your system will run 2019.5 just fine. (all HDX cards will get a firmware update so be prepared to let that happen when you first run 2019.5; it will show up and give you instructions)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
http://avid.force.com/pkb/articles/D...5-Release-Info Been away from studio so I have not upgraded yet but have been actively investigating doing so with my system (below) Quickly computer should work fine Do not "need Mojave" You will need to upgrade graphics card to run Mojave https://support.apple.com/en-us/HT208898
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
PT2019.5 and Mac 5,1 running HDX under the last version of High Sierra, has been the best combo to date, so update with confidence.
CPU usage is massively improved on third party plugin's that hogged cores, it's now very even, and minimal. Personally this performance optimisation alone has been worth the years subs.
[B][SIZE="1"]System: PT 12.8.1 HD-Native PCIe, 48 I/O 16x16, 2012 Mac Pro 12 core 3.46Ghz 64gig RAM, UAD Quad FW, Apple 30” Cinema |
Hi I have an early 2009 - upgraded to 5.1 with one processsor 3,46 GHz 6 core, 32 GB memory on mac os 10.12.6. Sierra I am running Pro Tools HDX with 2 DSP cards on 2 8x8x8 (one expanded in/out) Pro tools 2019.5 is running perfectly for almost 2 weeks now. I dont suspect you will have any troubles Best wishes Mogens Binderup Sent from my iPhone using Tapatalk |
PT2019 and Alt | babaorum | Pro Tools 2018 | 4 | 05-20-2019 11:01 AM |
PT2019.5 and Win10 | senghor | Pro Tools 2019 | 2 | 05-11-2019 08:50 AM |
