Old 05-16-2011, 04:29 PM
osborne osborne is offline
Default Pro Tools 9 I/O Setup
hi all,
i'm helping a friend set up their MBox 3/PT9 combo on their MacBook Pro. I'm still using the Mbox 2/PT8 setup so i'm a little confused about the I/O setup in PT9. I have selected "Avid Mbox" in the setup->playback engine menu but when I create a new track and attempt to record, the I/O on the track lists a bunch of inputs and outputs that don't make sense to me. Am I missing a step?
Thanks!
Old 05-16-2011, 04:46 PM
slater05 slater05 is offline
Default Re: Pro Tools 9 I/O Setup
Go to setup --> I/O and see what the inputs/outputs of the Mbox3 are listed as.
www.mikeslatermusic.com
PTHD9 Certified Operator
15" MBP 10.7.2
Pro Tools 10.0
Apogee Duet
M-Audio BX5A's
Old 05-17-2011, 06:25 AM
It gives me options like "built in mic 1" and "analog 2". Doesn't make any sense to me. Just seems like a jumble of mismatched inputs and outputs. How can i restore the default MBox 3 I/O settings?
Old 05-17-2011, 07:03 AM
nst7 nst7 is offline
Hit the "default" button on the I/O setup, I think that should fix it.
You need to do it for each section: Inputs, Outputs, Bus, and whatever else.
Old 08-15-2011, 12:35 AM
SimonInAustralia SimonInAustralia is offline
I think that if you hold down the option key when clicking the default button on one page, it should set the other pages to default as well.
Old 08-15-2011, 06:39 PM
bmuth bmuth is offline
I might be wrong since I don't have one here to look at, but if it's an mBox mini, wouldn't it only have the 2 inputs: a single mic and then 2nd 1/4" line input? (which you described as "built in mic1 and analog 2") That part of it sounds right to me?
Remember to show all women in pro audio extra respect- for they are the only women in the world that get excited when you show them your 2" !!!
Old 08-15-2011, 07:10 PM
Since Protools 9 also supports using the built-in mic input and audio out on the basic Macbook Pro, those are probably showing up also. Those should not be confused with the i/o on the Mbox3mini.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.15.6 running Protools 2020.5.0
Pro Tools 10 setup - need help onidub Getting Started 2 07-08-2013 06:19 PM
FWx and Pro Tools, tell me how is your setup doing? digidesigner VENUE Live Sound Systems 5 03-29-2013 10:41 AM
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
Mac setup for Pro Tools... pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 04-04-2008 11:11 AM
002 +pro tools setup blackshrek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-02-2007 06:21 PM
