Old 07-13-2020, 10:20 AM
JFreak JFreak is online now
Default Re: HDX card not found in new Thunderbolt rack mount chasis
Glad to hear you got it working. Avid maybe needs to refresh their readme/release notes. This is mentioned in Knowledge Base, but even fewer people read that than search for existing thread in this forum
Old 07-13-2020, 10:26 AM
It actually says this:
HD Driver may not load on macOS Catalina after installing Pro Tools (PT-257898)
When installing Pro Tools version 2019.12 and HD Driver version 2019.12 or later on macOS Catalina, HDX cards may not be detected when rebooting the computer. To correct this issue, do one of the following:
  • Manually load DigiDal.kext after every boot; Launch the Terminal and enter: sudo kextload /Library/Extensions/DigiDal.kext
  • For a more permanent solution, force an update of the pre-linked kernel via Recovery Mode in the Terminal: touch -c "/Volumes/Macintosh HD/System/Library/Extensions"
Old 07-13-2020, 10:28 AM
Actually the work needs to be done in the installer so that this is not missed and nobody needs to read any documentation.
True. It has a bug number so maybe next one has fixed the issue.
HD native thunderbolt with thunderbolt card on desktop PC? martthie_08 Pro Tools HDX & HD Native Systems (Win) 9 10-12-2016 10:26 PM
SATA card and Mix Card in Xpansion Chasis no go? Tim R. Pro Tools TDM Systems (Mac) 1 12-06-2004 08:31 AM
Firewire card in expansion chasis bob10s Pro Tools TDM Systems (Mac) 1 03-05-2004 06:31 PM
expansion chasis - USB card problems jeremyroberts Pro Tools TDM Systems (Mac) 5 03-21-2001 05:32 AM
second monitor card in PCI exp. chasis jim g General Discussion 2 02-19-1999 07:44 AM
