#31
Re: PT 11 won't import audio
Which OS?
#32
Could you give us any LESS info? Like what exact version of PT11, computer operating system, etc. If you're on a Mac and trying to import from a PC formatted drive you will have issues. Or if you're on Windoze and the drive has gone to sleep that could be an issue.
#33
Hello,
The computer is Mac OS ElCapitan, the Pro Tools version is 11.2. Other issues are seeming to occur like I can't save file as from the clip menu like I used to. Thank you for the assistance. |
#34
What does/doesn't it do, precisely? Any error messages? Spinning icon of death? Crash?
#35
Horribly useless amount of information here.
Starting with trying to import what exact format audio files into exactly what type of session format? And as already asked what exactly happens, exact errors etc? What file system type are you trying to import from/to? Are you trying to copying content or trying to leave it in place? If working with removable/interchange/external media first drag/copy any files to your audio/session drive and import the files from there. Hopefully you realize Pro Tools 11 is not officially supported on El Capitan, and it has known problems, but this is not one of them. This is either something simple like a corrupt session, or preferences, or you are not working on a HFS+ file system or have file system permissions wrong... You should check all those, try trashing preferences and starting with a new empty session, running from a new user account with admin privileges, etc. make sure your session or file content is not say on EX-FAT or NTFS media. And you have preferences set to always copy content on import. If it is not something so simple then nobody will have any idea and it is likely worth just trying reinstalling Pro Tools and if that does not work then do a full clean OS X install and install Pro Tools onto that, ideally a fully supported OS X version for Pro Tools 11. Install on a spare partition or new drive and just install the ILM, Pro Tools, no drivers etc. just use built-in output as the playback engine and test import works there. If so then add drivers, plugins and other apps. Do not use system migration assistant to move apps or drivers over. Trying fresh installs of Pro Tools 11 on El Capitan (vs insitu upgrading them) may run you into other known problems, so just better to be on a supported OS version. |
#36
The error comes up when I use Import Audio from the file pull down menu.
It does not give me an option to select a file of any format. I have attached a screen snapshot of the error. Here is the text from the error. Could not complete the Import Audio command because Assertion in "/Volumes/Development/151228/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559. Thank you. |
#37
So try trashing prefs, a new empty session, from a new admin account? Again if that does not work... next steps are reinstall Pro Tools, and eventually the OS.
Out of curiosity you can also try creating an audio track and drag and dropping content onto that. |
#38
Might be related to PT11 isn't qualified to work on OSX 10.11
I would start by trying to reinstall the last working version of OSX that was qualified to run PT11.3.2. I have a $100's that you won't have problems importing after that.... PT11.3 is cool with Yosemite 10.10.3 Go back to that one
#39
Of course with you trying to run PT11 on a totally unsupported OSX that is a major part of your problem right there. I love it when people don't pay attention to s/w compatibility when running a system. |
#40
This is a known issue. Avid is not going to fix this. Either reinstall Mac OS X v10.10.5 (or earlier) or upgrade to Pro Tools v12.3.1 (or later).
Any ideas how to fix this error during audio import: Assertion... line 603. | luism | Pro Tools 12 | 3 | 03-14-2018 11:36 PM |
Pro tools 9 assertion error cannot import any data | blazinbk | Windows | 4 | 04-30-2012 06:52 PM |
Can't Import Audio from QuickTime Video -- Assertion Error | David Ziegler | Pro Tools 9 | 28 | 09-18-2011 04:09 AM |
Error: "pro tools could not complete the import audio command because assertion in" | elsterNJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-15-2009 09:38 AM |
