Old 06-24-2017, 02:11 PM
jbandes's Avatar
jbandes jbandes is offline
Default Increase the Size of the Meters when Recording
I am running 12.7.1 and I am recording Reel to Reels in Pro Tools. I would like to know if there is a way that I can make the meters much larger while I am recording.
Also should I record as close to 0 db as possible or since its converting to digital should I record at a lower level for increased headroom?
Thanks all
Windows 10 Pro Version 1803
Asus ROG V 10
Intel i7-6900K 3.2 GHz 8 Core LGA 2011-v3
NVIDIA GeForce GTX 960 Ti
Samsung 960 PRO Series - 512GB PCIe NVMe - M.2 Internal SSD (MZ-V6P512BW)
32GB G.Skill DDR4 TridentZ RGB 3200Mhz PC4-25600 CL16 1.35V Quad Channel Kit
ASUS Expansion Card for Z170 & X99 Motherboards ThunderboltEX 3
Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter
Focusrite Clarett 4 Pre and UAD Apollo 8 QUAD
Pure 2 Mastering AD/DA Converter & Clock
UAD-2 Satellite USB QUAD
Old 06-24-2017, 03:32 PM
Default Re: Increase the Size of the Meters when Recording
Thanks all
Only thing you can do to the meters is make them wider in the MIX window. Hold all 3 modifier keys down and click on a track. Should you record as close to 0 db? Absolutely NOT. The whole point of that in the analog world was to maximize signal vs tape noise. With digital recording, there is no tape noise so get your meters to just hit the yellow and you will be in good shape(Yellow is the new red).
Old 06-24-2017, 06:44 PM
jbandes's Avatar
OK thanks I have the recording level where you suggested.
Forgive the dumb question but whta are all 3 modifier keys?
Asus ROG V 10
Old 06-24-2017, 06:48 PM
amagras amagras is offline
Control, Alt (Option) and Win or Command
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 06-24-2017, 06:50 PM
jbandes's Avatar
CTR, ALT SHIFT OK got it. Thanks.
Can I do it while it is already recording. Its about 1 hour in to a 3 hour tape? Does not seem to work while it is recording. I will try it when Side one is done and I flip the tape. Thanks
Asus ROG V 10
Old 06-24-2017, 07:00 PM
Ctrl Alt Win, no Shift
https://youtu.be/7pHmLAEXzhU
amagrasmusic.com
Old 06-24-2017, 07:03 PM
jbandes's Avatar
THANK YOU THAT WORKED
My old eyes are so thankful !
Much Better.
Asus ROG V 10
Old 06-24-2017, 07:06 PM
jbandes's Avatar
Much Better.
Now if they would only fix the tracking bug. in 12.7.1 when set to PAGE it sometimes does not scroll and goes off the screen. So annoying. They said they fixed it in 12.8 which I hear comes out at the end of the month. I have 100 of these reels to go so cant wait to see this fix its maddening.
Asus ROG V 10
Increase Font Size garden rock studios Pro Tools 9 6 04-06-2011 06:38 PM
Increase Your Buffer Size, It Says... Tom Hartman Pro Tools 9 11 03-31-2011 04:44 AM
Increase Buffer Size! Help! jjohns39 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-06-2010 12:24 PM
While recording - increase H/W Buffer size error barronosod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-22-2007 07:22 PM
increase buffer size manicero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2007 08:29 PM
