PT 12.7.1 on macOS 10.12.5 runs HOT!!
PT 12.7.1 on macOS 10.12.5 runs very very hot on both my brand new 2017 machines. I have a top of the line 2017 i7 iMac loaded up with RAM and also a new 2017 MacBook Pro i7 15". When running a very minimal session things heat up to sometimes mid 60 degrees Celsius. Same session running in Logic is running 10-15 degrees cooler. So I decided to try running PT in low resolution mode and bam, the machines run much cooler. Like only 5 degrees hotter than Logic running the same session. So my question is, when will PT be optimized to not do this? I've been reading that these sorts of issues have been going on for quite some time, especially with Retina display devices. I have also noticed that the GUI is quite snappier in low resolution mode. You don't see as much lag. That's another issues that has been plaguing PT for some time. So is Avid working on this at all? It has pretty much forced me to start using Logic solely. I don't feel like cooking any eggs and bacon on either of my Mac computers and burning out their CPUs and GPUs. C'mon Avid. Retina display Mac computers have been out for a very long time. There has to be some optimization that can be done in the software to make it run as efficiently as Logic.
Re: PT 12.7.1 on macOS 10.12.5 runs HOT!!
How and where are you measuring your temperatures? If internal then 60C on certain parts of the machine isn't all that bad with full resolution screen graphics (is that what you're talking about - you don't say). The thin iMacs do seem to run hot with the causing the fans to run crazy fast. Do NOT block the air intakes at the bottom of the screen and make sure the slot at the top is not blocked either (for optimal airflow).
Anyone have any useful info on how to get Avid's attention on this?
I would suggest to open a support case at my.avid.com, I don't think you will get any official answer from Avid here at the users forum, specially on a matter that will surely be treated by them as a particular problem of your systems.
macOS Mojave | Avid Pro Tools Duet, Apogee Groove & Symphony I/O | Pro Tools Studio 2022 Sound Engineer | Non-Avid Employee |
That's a shame, because it is by no means specific to my systems. I have noticed this for the last 5 or more systems I have had. Just finally felt like saying something about it. Bottom line is, as a Apple tech I can certainly tell you with some very elementary comparisons that their software is not optimized to use the CPU and GPU nearly as efficiently as Logic is.
And to be fair, at least on the same computer, heat generation is not much different with Cubase Pro 9.
It's not Avid's fault that software runs hot on 10.12.5 as it is Apple's fluke. All software runs hotter than necessary, even Logic. Once again they changed something that affects 3rd parties and we can only hope they fix it.
You're flat out wrong. This has nothing to do with 10.12.5. I am an Apple senior tech of 20 years who works in programming and beta testing and this "running hot" issue has plagued Avid back even before 10.9, and stating that Logic runs hotter as well is just plain laughable. I have two test sessions on my system that are identical, one PT and one Logic. Logic runs 10-15 degrees centigrade cooler all day long. This is an issue with Avid not optimizing their core PT code to utilize GPUs and CPUs more efficiently. All you have to do is switch PT to open in "low resolution mode" and watch core temps drop when running the same session that was just hot enough to cook on egg on. That in itself is the "A-ha!" moment. You'd be silly to say that Avid engineers are not woefully behind on prioritizing their focus to smooth out issues that have lingered for many years. It's all blatantly obvious. Pointing the finger at Apple is typical so I'm not shocked. I have an update for you though, Avid develops their software for use on Mac, not the other way around. Avid is privy to macOS betas day one. Bottom line is something is just rotten in Denmark and Avid has been dragging their feet for a long time. Sorry my friend, but you're just wrong. Proof is in the pudding, and the pudding is Logic running identical sessions with identical plugins and identical track counts 10-15 degrees cooler... To argue that is either denial or dishonesty.
Mac Laptop Runs Hot! | GeordiD | Pro Tools 12 | 24 | 06-26-2017 06:54 AM |
Latest Pro Tools LE version that runs on MacOS 9? | efernan1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-20-2004 07:15 PM |
Looks Like OS X, Runs On XP... | The Weed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 29 | 07-13-2004 08:47 PM |
Which Mp3 runs on OS X? | JimCutler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-04-2003 01:42 PM |
PTF runs on a PII 233 Mhz | Taja13 | Digidesign Hardware & Software | 1 | 10-26-2000 11:14 PM |
