Setting channel level numerically?
In PT 10 is it possible to key in a specific dB level in the mixer on a respective channel? For example I might want to set a level to -12.7 dB. How would I key in that specific value?
thx. -paul. |
Re: Setting channel level numerically?
I have never seen that ability - although I would like to have it also
One thing you can do is hold down the command / control key while you're Dragging the mouse and it gives you fine mouse movement Instead of the course normal adjustments
In the mix window, right next to the output on the track, click the little fader symbol,
a channel fader window pops up, there, at the numeric readout of the volume setting : click, punch in your value "-" , "12" , ". " , "7", enter, done
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
-paul. |
The little channel fader window , that might work for you as well :
click the numeric value (highlighted) and scroll up/down with scroll wheel. (One Hand action )
MC Mix Display Channel Name changes to level | seapea | Artist Series | 3 | 04-06-2011 11:19 AM |
setting record level | antwellington1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-18-2007 05:56 PM |
meters themselves to numerically show dB? how? | sonicz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-10-2006 12:35 PM |
Setting the level of the subwoofer | John Link | General Discussion | 11 | 07-24-2005 11:17 PM |
channel level mirrored in send level meter | daveh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-01-2001 01:32 AM |
