Old 06-04-2017, 12:42 AM
dBlever dBlever is offline
Default Line input L&R Issue
Hi all
This is my first post here but have had my 11R for about five years. Any help on this problem would be greatly appreciated. I want to use the line input of the 11R for my synth to free up inputs on my interface (Apogee Quartet). The issue is I cannot get a stereo signal on the outputs. I have the main outputs connected to the interface inputs and I have panned the Quartet outputs hard L/R. I eliminated this as a possible issue by hooking up my guitar and a ping pong stereo delay using the loop on the 11R and it worked fine. However if I connect the delay to the line inputs it comes out in mono.
I am hoping this is just a duh moment and it is possible...
Dale
Old 06-04-2017, 12:57 AM
You are trying to get the Line inputs on the Eleven Rack playing out its Main Outputs? Along with guitar rig outputs? ... You cannot do that, the Eleven Rack has no internal mixer, all you can do when it is stand alone to get the line inputs to the outputs is select the rig input to be line in. But then you lose guitar in processing and you likely don't want the synth going through the guitar rig.
When the Eleven Rack is used with Pro Tools as an interface, it is Pro Tools that provides the mixer to get the line inputs to the outputs.
The other option is to create an aggregate IO device in OS X. But that is likely not very stable.
If you need another analog input on the Apogee and you are burning one of them from the Eleven Rack, but unfortunately/stupidly the Apogee Quarter does not supports S/PDIF on its optical input. Which leaves about the only easy/reliable expansion options of getting an external ADAT preamp and connecting the synth to that.
Or just go all MIDI on the synth and handle it with a VI.
using HDMI input mutes line audio input of TV mr.armadillo Post - Surround - Video 15 09-24-2013 12:33 AM
XLR mic input or TRS line input on mbox craig123 Pro Tools 10 4 03-05-2012 01:42 PM
Defaulting to Mic input instead of Line input... a2zproductions ICON & C|24 2 12-09-2006 01:41 PM
THE LINE INPUT AND MIC XLR INPUT IN DIGI002RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-05-2003 01:26 PM
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2003 04:08 PM
