Old 08-10-2023, 01:41 PM
alecl alecl is offline
Default FMP not working as intended on Atmos tracks?
Why does turning on FMP on a send from a stereo track to an atmos (7.1.2) track only send to the side surrounds and not the front LCR?
Trying to send a stereo track to a 7.1.2 channel and want the tracks to remain in the front LCR speakers, however turning on FMP messes this up.
Photo attached.
Old 08-11-2023, 02:00 AM
Sonopolis Sonopolis is offline
Default Re: FMP not working as intended on Atmos tracks?
This is a general problem in Pro Tools. FMP does not work correctly if the bus width of the send is wider than the channel's main output width. In these cases only the channels present in the main output are being controlled by automation.
I think FMP should be disabled if the send's width is wider than the output but Avid does not see it this way.
Atmos on single PC system working Led Windows 2 04-19-2023 01:05 AM
Dolby Atmos Speaker Snap not working using Production Suite jamesa5454 Post - Surround - Video 3 11-02-2017 02:54 PM
Low Latency monitoring Aux bug? or intended Harleyman Pro Tools 12 0 12-04-2016 11:23 AM
Attention Avid. Ample guitar plugin not working as intended in PT11 AAX protoolsuserman AAX Plug-ins 3 03-08-2014 12:18 AM
Feedback on a song (no pun intended) Travis Mitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-25-2002 05:30 PM
