  #61
Old 06-29-2023, 08:32 AM
dansoundmix dansoundmix is offline
Default Re: Always having to force quit Pro Tools
Originally Posted by Tobias Eichelberg View Post
I experience the same behavior - work all day on a session, then Pro Tools will hang when I try to quit.
I'm on a late 2019 Xeon/Intel Mac Pro - so it's not just the Apple Silicon users affected.
I too experience PT hanging when trying to quit which results in having to Force Quit. PT Ultimate 2023.3 running in Rosetta , Apple Studio M1 Max, Monterey 12.6.5. I agree that it almost always happens after a full day of work rather than a quick session.
  #62
Old 06-29-2023, 08:57 AM
wwittman wwittman is offline
Happening to me fairly regularly with essentially that exact same config.
I can’t say I’ve noticed a pattern.
It happened to me yesterday after only having PT open for about 2 hours.
I’m just getting used to it as the new normal.
Which is, of course, a bit ridiculous.
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
  #63
Old 06-29-2023, 09:37 AM
JimaSound JimaSound is offline
I am still having this happen intermittently (around 50% of Pro Tools - quits) since I reported it in this thread in mid February on my MBP Max M1, MacOS 12.6.7, PT 2023.6 system.
  #64
Old 06-29-2023, 09:45 AM
paul_g's Avatar
paul_g paul_g is offline
Same here, when I close PT, I get the "PT Closed Unexpectedly" or some silly nonsense. I can ignore, retry.
I've had this issue for a while. I delete prefs and it goes away, but it must be important, because it come back. :)
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
  #65
Old 06-29-2023, 10:32 AM
marianna's Avatar
marianna marianna is offline
Hey Dan,
I created a case on this for you and have assigned it to tech. case 04647081 and hopefully between the 7 pages of comments they can figure this one out.
marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
  #66
Old 07-08-2023, 01:52 AM
uptown's Avatar
uptown uptown is offline
Acknowledging that I don't have an approved configuration (Pro Tools 2023.06 on a 2010 Mac Pro running OS 12.6.7), I have found that no matter whether I start PT with only the stock plugins and then immediately quit, or run for several days with all the third-party plugins too, I always have to force quit when it's time to quit PT.
However, if I change playback engines and PT has to quit to work with the new engine, it quits fine.
Kind regards
Murray
Murray Anderson
Milestone Studios
21 Bloem Street
Cape Town 8001
South Africa
https://www.milestones.co.za
Tel: +27 (0)21-424 6000
  #67
Old 07-08-2023, 02:07 AM
EmilILönneberga EmilILönneberga is offline
That’s an interesting observation. I’ll try that. Thank you!
  #68
Old 07-08-2023, 08:51 AM
Joe Costa Joe Costa is offline
Yes!
I was just going to post this as well. I have the same issue as most here. I have to force quit at the end of the day. I can reopen that session after force quitting and it will quit normally. It happens over time and this issue started creeping in a couple of weeks ago. I'm on a 2018-2020 mac mini running 10.15.7. I upgraded protools from 2022.10 to 2023.6.0 to see if that would help. No difference. Yesterday I tried an experiment. At the end of the day, AFTER closing the session and before quitting protools, I switched the playback engine to "Mac Mini Speakers". Then when quitting protools, it quit normally. Hopefully others can try this and see if it works on their systems. Maybe it helps AVID to pinpoint the issue.
Mac Os 10.15.7
Protools 2023.6
  #69
Old 07-08-2023, 08:28 PM
Originally Posted by Joe Costa View Post
Yes!
Ugh. Well, it let me quit normally twice with this method after having to force quit all week. Now I STILL had to force quit this evening after switching the playback engine. Oh well.
Mac Os 10.15.7
Protools 2023.6
  #70
Old 07-13-2023, 12:29 PM
Sonopolis Sonopolis is offline
Same problem. MacStudio M1, Monterey, PT2023.6 in Rosetta. Not always, but 80% of the time "closing session" hangs.
Pro Tools Crashes, Keeps Running in Background After Force Quit gabriel b. Pro Tools 11 2 01-07-2018 12:58 PM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
The following incident with Altiverb will force me Force Quit PT 25ghosts Pro Tools TDM Systems (Mac) 0 03-02-2009 01:30 PM
Pro Tools 7 will NOT force quit... soundfx Pro Tools TDM Systems (Mac) 2 04-20-2006 03:04 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
