Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 01-15-2020, 02:13 PM
BaroqueWorks BaroqueWorks is offline
Default HD OMNI - No firmware, can't install one.
Good day,
One of our HD omni had no firmware installed in it.
This happened because of a software update gone wrong / interrupted.
There is no way to reinstall a firmware in it, even through DigiTest.
When powered on, the HD OMNI has an amber LED, nothing appears on the PREAMP and MONITOR screens, and the fan is blowing hard.
During the update process, Digitest tells me to hold the "Set" key while rebooting, even though this button doesn't exist on this hardware.
Then this message shows up "Firmware update aborted: Couldn't establish communications with the SYNC HD. Please power cycle it while holding down the set key."
https://imgur.com/a/RcpsipD
We tried the procedure with every keys available on the OMNI, to no result.
There's is no help online, I tried many computers, many digilink cables.
https://imgur.com/e6c6GuS
https://imgur.com/qFYSH56
Help?
Old 02-10-2020, 03:13 PM
Raytown Raytown is offline
Default Re: HD OMNI - No firmware, can't install one.
Hi there. Sounds like the firmware may have been corrupted due to the failed install. Have you tried factory resetting the Omni?
1) Quit ProTools.
2) Unplug the Digi Link Cable.
3) Press the SETUP button on the front of the HD Omni.
4) Scroll the Monitor knob to “Reset”.
5) Press the Monitor knob, then press the Monitor knob a second time to confirm.
Try that then try the firmware update again and see if that works.
Cheers,
Jonny Ray
Old 02-13-2020, 09:43 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
SO are you trying to update you OMNI HD with SYNC HD firmware?????
IMDB
Omni firmware question s.d. finley Pro Tools HDX & HD Native Systems (Mac) 6 01-04-2018 02:43 PM
PT HD Omni sin firmware Limoncarro Foro en Español 2 05-04-2016 06:30 AM
OMNI firmware & revision redbor Pro Tools HDX & HD Native Systems (Mac) 9 01-08-2014 03:24 PM
HD Omni Firmware Stuck at 78.44% Oblivion777 Pro Tools HDX & HD Native Systems (Mac) 9 04-19-2013 07:24 AM
