Old 12-08-2013, 03:45 AM
JamieOxford JamieOxford is offline
Default Importing Preferences to Pro Tools 11
I just upgraded to Pro Tools 11 from 10.. It's working well but I wondered if anyone knows how I can import my preferences from 10 to 11?
I have a list of 'favourite' plug-ins that show up under the inserts without having to go to EQ/dynamics/delay first. There's also session templates, fade preferences, pan depth in sessions and a bunch of other stuff that I've set up over the past couple of years. Obviously I can do this manually but it'd take a while to sort everything out.
Is there a quick way I can import the preferences?
Regards,
Jamie
Old 12-08-2013, 04:04 AM
musicman691 musicman691 is online now
Default Re: Importing Preferences to Pro Tools 11
Regards,
Jamie
PT11 does a pretty good job of picking up on preferences that you have in PT10, at least it did on the system in my sig file. You don't say what operating system you're on so on Windows it might be different. For whatever plugin you have setup to come up first, if you use the standard Avid way of picking it that's easily setup in Preferences if it isn't picked up immediately. Ditto for pan depth prefs as well. I don't use customized session templates so can't help there. But if you do use the track presets hack in PT10 be aware there's a new location for that folder in PT11 and on a Mac it's in an Avid folder off your Documents folder.
Jack
QAPLA!
Old 12-08-2013, 05:11 AM
Drew Mazurek's Avatar
For such a major change in versions, I'd recommend you rebuild EVERYTHING. I do it for all .x releases.
Sometimes bugs can be carried forward into newly made sessions through old I/O settings, templates, etc.
PITA I know, but that's been my experience.
www.drewmazurek.com
Pro tools 10 resets preferences hanzzi macOS 5 10-24-2018 10:04 AM
Delete Pro Tools Databases and Preferences mikeyman Pro Tools 10 21 01-27-2013 04:28 PM
How do I trash Pro Tools Preferences in Windows 7? cdvh5150 Windows 4 11-21-2012 04:29 PM
Cant Start Pro Tools 9 Without Deleting Preferences Ike Productions macOS 0 04-30-2011 10:19 PM
Custom scripts for Pro Tools preferences in OS X tapperdapper Pro Tools TDM Systems (Mac) 0 06-10-2004 11:24 AM
