Old 11-21-2020, 06:56 PM
clonewar clonewar is offline
Default Do Insert Controls Spread Across Multiple S1's?
I'm considering moving to a multiple S1 setup and want to know if Insert/EQ/Dyn controls spread across multiple units? If I have four S1's will I be able to use the 32 encoders to control an open plugin?
Old 11-23-2020, 03:45 PM
Default Re: Do Insert Controls Spread Across Multiple S1's?
Bumping up.. Can Eddie or anyone with multiple S1's answer this?
Old 11-23-2020, 04:21 PM
pavoni pavoni is offline
I have 2 Artist mixes, and yes EUCON spills across whe whole surface.
Old 11-24-2020, 08:04 AM
Lynn Gräber Lynn Gräber is offline
Yes it does. However, if you're concerned mostly with plugin tweaking, I'd seriously look at a S1 and a Dock combo if your budget or space allowance is only a few units.
Old 11-25-2020, 08:54 AM
EddieJones's Avatar
Yes, any function can spread across multiple S1/Mix units knobs. Its called Channel Mode.
Izotope Plugins Insert Controls a12izabal Avid S1, S3, Dock and Control App 0 10-20-2020 12:48 PM
DNS one controls "reversed" when in insert mode espron Artist Series 2 08-20-2018 02:09 AM
Move/copy multiple plug-ins to other insert slot at once pericoloso Pro Tools 11 14 07-11-2014 08:48 AM
Group Attributes Insert controls mono / stereo crizdee macOS 1 09-24-2013 01:10 PM
group attributes insert controls stereo/mono channels Dusty Angel Pro Tools 9 1 05-26-2011 03:46 AM
