Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 03-28-2020, 01:22 PM
emf1138 emf1138 is offline
Default S1 randomly writing PAN automation
Just installed an s1 on my work's PT Ultimate system (2018.10) and when I hit play, a track will randomly start writing pan automation. Any idea why? I started with Eucon 20.1 and then downgraded to Eucontrol 19.12. Happens on both versions.
Upgrading the PT software to the lastest version is a bit of a challenge since it's a corporate system, but I guess these days, it should be easier to get approval.
Eric Freeman, CAS
Sound Supervisor/Re-Recording Mixer
Disney TV Animation
IMDB
LinkedIn
Old 03-28-2020, 05:39 PM
brianpaturalski brianpaturalski is offline
Default Re: S1 randomly writing PAN automation
I had this happen when one of my knobs died - you could see the oled display fluttering around a little on the numbers even when untouched. It ended up needing to be sent in.
Old 03-28-2020, 06:01 PM
Yes, I've seen the display slightly flutter. This is a brand new S1. Not even 5 days old. Ugh, I hope that's not the case.
I just upgraded to 2019.10 and Eucon 19.12.1 and it's still happening.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 03-30-2020, 03:40 AM
cablenaute cablenaute is offline
Hi Eric, you should have a look at this thread
Old 03-30-2020, 02:50 PM
Yes, thank you! This is the same problem, however I WAS able to get a replacement unit from my dealer today and the EXACT problem is happening on the second unit as well. Any other ideas??
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 03-30-2020, 03:07 PM
I trashed PT prefs and that did nothing. I've upgraded to latest Eucon 20.1.0.50 and problem is still there.
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Old 03-31-2020, 01:56 PM
EddieJones's Avatar
You need to contact Avid Support to get a replacement not your dealer.
Old 06-05-2020, 09:39 AM
francisrl francisrl is offline
I've been having the same issue on my Avid s1 since march
Windows 10
Pro Tools HD v.12.5
EuControl v. 20.5.0.149
Avid s1 Firmware v. 20.5.5.0
  • Knob on channel #4 is flickering and writing pan automation without being touched.
  • Pans are being randomly resetted to 0 as I'm nudging from track to track. Selecting a track from Pro Tools will get the same effect. I'm not 100% sure it's related to channel #4 on the s1 but it's probably safe to assume so.
  • I'll send it back as it's still under warranty from the store but it looks like a common problem from the early models.
Old 06-05-2020, 10:30 AM
Contact AVID ASAP. They sent my replacement very quick.
Windows 10
Pro Tools HD v.12.5
Eric Freeman, CAS
Disney TV Animation
IMDB
LinkedIn
Automation not writing Jenre Windows 7 07-02-2014 11:04 AM
Automation writing on it's own cananball Post - Surround - Video 4 06-28-2014 12:36 PM
Writing Wah automation from GR5 tha]-[acksaw General Discussion 1 02-14-2014 12:44 PM
Writing automation? danander11 Tips & Tricks 2 11-22-2009 09:24 PM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 03:41 PM
