![]() Quote:
AVID just informed me that there will be a Firmware Tweak on the coming Eucon Update which will significantly improve fader performance.
![]() Quote:
no biggie, they've since acknowledged to me there's an issue and they're on it, |
Same behaviour here, touching a fader on S1 writes volume automation in Protools somewhere between -0.5 and -0.9… just forget using faders without having to thin automation manually…
A fix would really be appreciated. Thanks!! Last edited by cablenaute; 02-10-2020 at 02:19 AM. |
Had the first test with Eucon 20.1.0.50.
The fine adjustment of the fader movement is much better. Faders changing level on touch is marginally better than before. The faders still re-adjust as before but Instead of up to +/- 1db differences, they only move +/- .1 to .5 db So, no the Eucon update and S1 firmware update didn’t quite fix it. |
![]() Quote:
How to calibrate 96 i/o | EarHole | Pro Tools TDM Systems (Mac) | 3 | 06-06-2009 10:26 PM |
Calibrate the faders ?! | Luzer | ProControl, Control|24, Command|8 | 2 | 05-08-2006 04:19 AM |
calibrate system | drenched | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-20-2003 07:24 AM |
calibrate i/o | DeadboysThing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-24-2003 08:41 PM |
How often do you calibrate your 888's? | Anibal | Tips & Tricks | 0 | 02-08-2000 09:33 AM |
