#21
Re: export list of music clips for cuesheet
Yeah. Me, too.
sent from a stupid phone using Tapatalk |
#22
Ya, good idea, never thought of that. I guess I got spoiled as the assistant that finishes the cue sheets already knows that it should ignore the duplicates
Regards, Paulo M MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura Protools Studio 2024.3 |
#23
Somebody just asked me about having one name across multiple crossfaded clips.
The answer: That only works when using the session text export from Pro Tools rather than direct session import into PG PT Session (currently) and you need this option selected on the crossfades: If the Fade Handling option isn’t set to “Combine Crossfaded Clips” you’ll get all individual clips. The only dangerous thing about this option is that if you crossfade unrelated music tracks it’ll only take the name of the first one then use that for the whole duration of the amalgamated clip (potentially across many crossfades). Cheers, Pete |
#24
If using your "remove suffixes", two adjacent clips that are edits/crossfades of the same clip would end up with the same name. Crossfades into different clips (which for the purposes of a music cue sheet need to stay separate even if overlapped/crossfaded) would stay as separate line entries.
#25
Pete |
#26
When I've had to do this, I begin by splitting the mx tracks to mono. I guess if it's stereo, the list created will have two entries for each cue (.L and .R) and it is easier to read if it's only one for each cue. Then I go through and delete any clips that aren't mx (2pop) or are muted. Then, highlight the tracks you've created and modified, and export selected tracks as text. You can play with the exact setting s you need from there, but a pretty common set up I use is in the top section, to check only the "Include Track EDLs" button (selected tracks only) and then in the bottom, I usually set it to combine crossfaded clips.
#27
Thanks.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
#28
Export clips with fades | jgiannis | Pro Tools 10 | 3 | 03-17-2021 04:02 PM |
Music cuesheet | mihaicoporan | macOS | 3 | 04-04-2019 03:45 AM |
Exporting Clips as WAVs, clips dont highlight in list | gigantorbuzz | Pro Tools 10 | 6 | 08-05-2013 01:07 PM |
Export Midi Clips | txshonk | Pro Tools 10 | 2 | 04-06-2013 08:28 PM |
AV4.0 ADR Group Clips export | alex weber | Post - Surround - Video | 1 | 06-23-2010 06:05 AM |
