Recording problem in Pro Tools LE 6.4 (Windows XP)
When I go to record Pro Tools freezes for about 1-2 minutes then records. Is there something I need to change in the preferences?
Re: Recording problem in Pro Tools LE 6.4 (Windows XP)
I have that problem once and awhile(Only when I use reverb or have alot of plug-ins on the session), Make sure you have nothing else running while running PT(Except other music apps that you want running with it), CPU usage is at 85% and if you haven't make sure you read the manual and change the settings that digi suggests.
[TheLP] |
amthompson ,
I'd try the usual suspects first ; -a separate, 7200 RPM audio drive ? -DMA enabled ? -record time allocation..( set it to length of session ) How does PT do with playing back a session ? We need some more system info... cheers,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
You can try setting record allocation time to 10 minutes.That would be in the Preference menu.That does help some people.
Bazzle |
Recording with Pro Tools Express on Windows 7 | Countryboy-1970 | Pro Tools Express on Windows | 1 | 07-09-2012 12:26 AM |
Pro Tools 8.0.4 for Windows 7 - Problem - Need Help! | fender126 | Eleven Rack | 24 | 03-15-2011 11:20 PM |
Protools 9 and Mbox2 Windows 7 recording problem | b.scarz | Windows | 7 | 12-12-2010 06:41 PM |
Pro Tools not recording after windows update!?!? | hac23_99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-14-2010 06:24 PM |
Pro Tools LE 7.3(problem on windows) | SkyHigh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-15-2009 06:06 PM |
