Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 10-03-2019, 12:29 PM
soundartsonline soundartsonline is offline
Default How to change colors of tracks/ Protools 11.1.3
Specifically: colors of clips. I see no option for doing this. Been looking
Why does Protools make this so difficult?
I'll be checking back in for suggestions.
Thanks!
Lisa
Old 10-04-2019, 11:26 AM
Default Re: How to change colors of tracks/ Protools 11.1.3
Pretty sure its found under the Preferences sub-menu. There's quite a lot of stuff in there that's worth learning, so I would dig thru the help files a bit, and search youtube for some video guidance
Old 10-04-2019, 11:32 AM
Benoni's Avatar
Benoni Benoni is offline
Its done the same way for the last several versions of Pro Tools, with the Color Palette. Just select a clip with it open and it should automatically change to clips.
Here's a couple videos
Pro Tools | Color Clips on the Timeline LIKE A BOSS!
https://youtu.be/SnpsxoR-hM0
Pro Tools | Color Clips in the Clip List LIKE A BOSS!
https://youtu.be/_Laui6VYu_o
Pro Tools | All Colors the Same LIKE A BOSS! (Tracks, Clips, Clip List Colors)
https://youtu.be/g2c82Ln_k78
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 10-04-2019, 12:45 PM
Benoni,
Protools 11 does not have that option unfortunately. I've tried many times. When I click on a clip it brings up a window but not the color palette.
Thanks,
Lisa
Old 10-04-2019, 12:48 PM
Dave,
No such luck under preferences. Tried that already. All you get is the option to select track color on the submenu, but after that nothing happens. No color palette offered. It's like they forgot to add that in this version of Protools.
Pretty annoying.
Thanks anyway,
Lisa
Old 10-04-2019, 01:17 PM
Benoni's Avatar
Originally Posted by soundartsonline View Post
Benoni,
Thanks,
Lisa
Did you watch the videos?
You don't click on a clip to open the Color Palette, you double click on the strip at the bottom/side of a track or open the color palette from the WINDOW menu (shown in videos). Then you clip on a clip to select the source for the color transformation or switch it from the Color Palette menu.
Are you using Pro Tools 11 FULL VERSION or First?
Because it's definitely in PT11.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Unable to change marker colors foxes Pro Tools 12 12 07-18-2017 05:48 PM
How Can I change the Track Colors?? bcrichguitar Pro Tools SE and Essential (Mac) 3 12-04-2011 08:56 AM
is there a way to change the default colors for tracks blackmajik2021 Pro Tools 9 11 12-13-2010 10:11 AM
Change Track Colors JHJ Pro Tools TDM Systems (Mac) 14 01-06-2007 05:25 PM
quick stupid question...how do you change colors?? ejsongs Pro Tools TDM Systems (Mac) 0 11-14-2005 07:45 AM
