Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
  #21
Old 12-21-2008, 07:04 PM
Skyflash Skyflash is offline
Default Re: ProTools 8 - Input Monitoring "Off"
Why not just write the punch in mutes as automation?
When the track is done being recorded just wipe the automation data or create a separate playlist
in case you need to go back. Mind you I agree 100% with the opinions expressed here regarding
the software monitoring. This could be a work around.
  #22
Old 12-22-2008, 06:16 AM
martthie_08 martthie_08 is offline
because it is a lot of hassle and you may not know in time ahead when you are actually gonna punch in! For example, when doing band recordings I punch in not before I know the band is in locked in and know at what position they are playing.
I always respected Digidesign to have very well though out workflows in their software, as opposed to Logic which just throws a ton of possibilities at you giving you ten different ways to go from A to B. But in this matter there is a strong need for them to see how not being able to turn software monitoring off is a serious issure for many users.
  #23
Old 12-22-2008, 04:52 PM
ah Yes I can see then. writing all those in would be a PITA if you are
tracking a whole band.
  #24
Old 12-22-2008, 05:18 PM
maufau maufau is offline
Red face Re: ProTools 8 - Input Monitoring "Off"
Even when just recording 1 demo singer it is an issue to write automation for recording. If you've ever recorded 42 tracks of vocals (POP/R&B) you will see. The singer says - "o.k, I'm gonna stack this harmony part 4 times each for the low mid and high harms" - thats 12 tracks (which doesn't include unison back vox)...So I go through track by track as she stacks the word "sexy" or some b.s., and I am to write mute automation too? Not likely. And have to remove it afterwards too?
So here is the workflow currently...
1) Make selection with edit cursor then use ; & P with (track selection follows edit selection)
2) Record enable track with mouse (will now use shift+R - woo hoo!!!!)
3) hit f12 - stop when needed
4) record enable next track with mouse
5) hit f12 -stop when needed
add mute automation in there and you can see where it gets a little insane
this is done up to 20 times per harmony vox area per session depending on how much harmony a singer or their songwriter wants on a particular word.
Dunno seems like a bit much...
Allow us to turn it off, or allow us to mute during a punch pass, or allow the opposite of input only monitoring = track only monitoring. All of them are fine for us really!
  #25
Old 12-29-2008, 10:14 PM
vitamineli vitamineli is offline
Sounds like you need a Mackie Control, or some other hardware device to hit mute and record at the same time. This is how I handle it. actually I find it easiest to hit mute with my left hand on the MCU and 3 on the number pad with my right. Keeps me on my toes...
I find the control surface indispensable for that kind of "two-tasks-at-once" kinda thing.
A Digi 003 doesn't have the mix knob that someone was asking about earlier in the thread, to my knowledge. Only Mbox family...
Eli
  #26
Old 12-30-2008, 02:23 PM
DigiTechSupt's Avatar
It doesn't because it has the option for Low Latency Monitoring.
Avid Audio Tech Support
Support FAQ
  #27
Old 12-31-2008, 03:56 PM
Eli
Again, this does not work with punch ins. As an artist/instrumentalist needs to hear the previously recorded material
  #28
Old 01-12-2009, 01:01 PM
cdmstudios cdmstudios is offline
I have to chime in here too and say that this is a really important thing and I can't believe it still hasn't ever been implemented. I have a 003 and I wouldn't feel all that comfortable recording at 64 or 32 samples if I knew it was mission critical. I want to turn input monitoring OFF and just monitor through the Mic's channel in my hardware mixer and then monitor playback from my record track in Pro Tools for punching in.
Please consider this for an update of Pro Tools 8.
thanks
  #29
Old 01-12-2009, 01:10 PM
peppertree peppertree is offline
I had read that Pro Tools 8 Native systems would have the "I" button for input monitoring on every channel strip, as HD does, but then I get the product and they scrubbed it out at the last minute...
  #30
Old 01-12-2009, 02:55 PM
Shan's Avatar
Shan Shan is offline
Where did you read this? That was never promoted in their literature.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
PT 10 "new" software input monitoring option? GKinTN Pro Tools 10 46 08-10-2014 03:57 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Channel I/O keeps loading old I/O and not "no input"/"no output" Arve Gotfredsen macOS 4 02-12-2013 04:38 AM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled OKden Pro Tools TDM Systems (Mac) 2 10-27-2001 03:24 AM
