#21
Re: Mid Side Miking Technique
I just went through almost the exact same arguement over in the sound designer´s mailig list. I simply wanted to explain the theory behind MS and what is good in MS. I have used all sorts of recording setups depending on what I record so there is no need to convince me that MS is "sort of OK", "boring" or lacks depth. Especially the latter can be read in every book about micing techniques that MS offers great L,R localisation but offers less precise depth than micing setups that induce delay between the two mics like AB, ORTF, OSS, etc. etc. etc. If you think MS is crap well so be it. But: referring to the original question of the first poster: MS is as "real" as AB, ORTF and all the others or as "unreal". You can chose. Because none of the stereo setups project reality by 100% the argument is rather useless.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#22
check out this link. It explains in detail, but to sum it up.... the center cardiod mic is recored to 2 tracks... center. the figure 8 mic is recored to L in phase.. ( make sure the front of the mic faces left) the back of the mic (facing right) is phase reversed and recored to the right channel. This is how the immaging works. a center signal is disregarded by the figure 8 mic. If a signal is on the left (front side of the fig 8 mic) is sums with the center mic on the left side... and cancels with the out of phase fig 8 on the right.. thus panning the signal to the left. If a sound comes from the right ( the back of the fig 8 mic that has been phase inverted) Since the mic has been phase inverted, the back of the mic now outputs positive phase information on the right side, thus summing with the center mic on the right/ canceling on the left, and causing the sound to pan right.
I hope that makes sense... if not, check out the link TL http://www.paia.com/msmicwrk.htm
TL Warner Bros. Studios |
#23
Reading (and re-reading) the whole thread leaves me with the distinct impression that you actually might be looking for an argument. Moreover, you’re the only one having an argument. Monte is a big boy and doesn’t need others to come to his defense. Nonetheless, he never referred to MS - or anything else for that matter - as being crap, nor did he make any disparaging comments about the various solutions. He stated his personal findings in comparing stereo mic techniques. Your questions to Monte, on the other hand, struck me as being confrontational from the outset. While I am familiar with the techniques being discussed here, and have formed my own opinions about each, I’m always intrigued to hear/read other fellow engineer’s take on the same. As such, I found all posts in this thread to be interesting and useful… until your last one. Out of curiosity, how much love did you get “over in the sound designer´s mailing list?”
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
#24
Andre baby,
I don´t need a chill pill at all. I just think that we are talking about two different things. In the beginning someone was having problems with an MS decoding. I chimed in and clarified some things about MS and how it works. Then all of a sudden other people chimed in stating that MS is actually not as good as other techniques. Fine. When I said "rediculous" I meant that I felt that we were talking about two different things that had nothing to do with each other wihtout stating that either one was wrong or right and that we were about to get into a serious arguement about two different topics one about how MS works and one about wether it´s better or worse than other stereo techniques. Maybe the line that ended with "..so be it" was a bit harsh, I admit. Your last question I´ll feel free to ignore if you don´t mind. I don´t understand the word "love" maybe a side effect of the pills... frank.
#25
for anyone who cares, M/S really is true stereo also because the figure 8 "S" mic gets positive and negative acoustic energy from the "front" and "back" of the mic, respectively. copying the figure 8 mic signal, and flipping one out of phase decodes this postive/negative acoustic energy from a once mixed signal. it was acoustic phase until the mic picked it up, its electrical polarity at this point.
"fake stereo" would be having a mono mid mic and a non-figure 8 mic as the S. then you would be flipping a mono signal out of phase and just getting a phasey signal around your mono mic. a cool thing to try when doing M/S - try an omni mic as your mono/middle source! |
#26
Hey Monte,
Out of curiosity, how do you feel about mono buttons and spaced pairs? Regarding MS, one of the things I like best about it is that if the thing that you are recording is in front of the mic, it's mostly represented on-axis by the M mic. With crossed figure-of-8's, any source directly in front of the recording setup is actually a bit off-axis to either of the mics. I think each technique (ORTF, M-S, Blumlein, Decca Trees, etc.) has its applications, plusses and minuses and I'd choose different techniques depending on what I was recording, the room I was in, how much ambience I was trying to capture, the availability of mics, etc. Regarding decoding M-S in Pro Tools, I do what was described ealier (duplicating the S track, inverting the polarity of one and panning them hard left and right). I then make a mix group of the two S tracks to link the faders. When working with M-S decoding, I'll start by setting the M level first, and then bringin up the linked S tracks until I hear the stereo width I'm looking for. I think it's pretty important to hit the mono button from time to time while doing this; you can create a greatly enhanced stereo image with an elevated S level but the price of it will be low volume in mono. Regarding compression, I use stereo compressors with M-S signals with no problem, as long as the compressor has truly linked side chains. I don't like compressing the M and S signals independently, due the the size of the stereo image changing with varying levels of gain reduction. Nice thread. - Stan |
#27
Having a mono button in PT would be very helpful.
#28
As a workaround, I’ve been inserting a bypassed Waves S1* with the image control collapsed to mono. When I need to check mono, I simply defeat the plug’s bypass. All my stereo templates feature the above on my “monitoring out” master fader. * But any stereo plug in featuring panning controls for its two channels will do just a swell. If you run out of DSP, deactivate the plug instead of bypassing it. IHTH.
#29
In practice, it doesn't seem to be a huge problem to sum a spaced pair like an ORTF array to mono. Quote:
A mike like the KM-84 has a really nice polar pattern in this respect. The front half hemisphere has pretty much the same frequency response, making it work really well for all of these sorts of array techniques. Most small capsule mikes are only a little worse, especially at high frequencies, but many large capsule mikes have very significant colorations at 90 degrees, making them less useful for arrays. Quote:
-monte- |
#30
I built a MS matrix using the schematic at the jensen xformer site as a guide:
http://www.jensen-transformers.com/as/as065.pdf I put the mics through the decoder before the preamp. One advantage of MS is that you can use different mics. So, if you're on a small budget and your best mics happen to be your matched pair, you don't have to commit them both to overheads. just my 2 cents. YMMV. byron |
Side-by-side configuration error | peter5992 | Windows | 15 | 05-18-2012 08:30 PM |
can I use the Mbox2 side to side to an Omega Lexicon?? | nastyartproduction | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2010 06:46 PM |
New: Lopes Stereo Miking Technique | Alécio Costa | Pro Tools TDM Systems (Mac) | 9 | 02-14-2009 09:12 AM |
Digi,Side by Side errors in event viewer with PT's HD 7.4? | x9blade | Pro Tools TDM Systems (Win) | 8 | 12-15-2007 11:19 AM |
Mid-Side Mic'ing (not the technique, the mic) | Ryan Young | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-26-2006 03:04 AM |
