Old 02-17-2013, 01:05 PM
peter5992 peter5992 is offline
Default How to get of the Plosive?
Good morning everyone:
Hope you are enjoying the President's Day weekend.
Quick question: I am editing the dialogue of a short film, including implementing ADR which someone else recorded. Unfortunately I only have one take and a few words (starting with plosives like p etc) sound bad, presumably because no pop filter was used or perhaps placed incorrectly.
We will probably have to ask this actor to come back into the studio for more ADR (there's other dialogue which is bad as well), but just for my curiosity and education, how would you fix this if you couldn't do the recording again?
I have PT10 with the CPTK and Izotope RX.
Many thanks!
Old 02-17-2013, 01:17 PM
Mitch Griffin Mitch Griffin is offline
Default Re: How to get of the Plosive?
....or, if you look at the waveforms of those 'Ps' popping, you can edit the incoming 'p' and make a fade. It can be work intensive, but can eliminate a VO redo.
Old 02-17-2013, 01:44 PM
JKD99 JKD99 is offline
I select the 'plosive, then use EQ 1-Band in AudioSuite mode with a low cut filter at around 180 or so. That will usually take care of it. Adjust the freq to taste so it gets rid of the pop and doesn't make the voice sound too then.
That said, if you're getting 'plosives recording ADR (as opposed to Narration/VO) then your actor is probably WAY too close to the mic.
Get a little distance on it and you'll not only get rid of the p-pops but it will be easier to match into production when you mix.
Best,
Joe
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 02-17-2013, 01:47 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
I high-pass them with an Audiosuite equalizer. My favorite for this is the Waves LinEq Lowband set to Low Ripple. It works so well that I never use pop filters these days.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 02-17-2013, 03:51 PM
minister's Avatar
minister minister is offline
Then open RX, Spectral Repair, bump the strength to 1.5 or 2, reduce the Surrounding region percentage to 50 or 25, Capture, lasso the "plovsive", repair, render.
Far more control than a hi-pass solution.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 02-17-2013, 05:54 PM
I use the spectral editor in Samplitude for that when I'm mastering because its faster but that particular waves high-pass filter is still the most reliably transparent method I've found.
Interview
Old 02-17-2013, 08:00 PM
Thanks for the feedback everyone - I tried high passing the passage with one of the EQs but that doesn't work - still hear the plosives when I move the filter pretty high up. For RX, I have Declicker, Declipper, Decrackler, Denoiser, Hum Removal and Denoiser (RX3), but no Spectral Repair.
Well -- whatever. Met with the director and we're going to try to bring the talent back in for another VO session. There are more issues than the popping, some lines are delivered differently as well, and some lines have a huge amount of background noise that I don't want to try to filter out.
Thank you for the feedback, have a great weekend.
Old 02-17-2013, 08:02 PM
I do just the pop. You can see it in the waveform.
Interview
Old 02-18-2013, 02:13 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Use a different "P" from another piece of dialog. I have even patched a couple of consanants with my own voice, and if you do it right, the results can be amazing.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 02-18-2013, 05:15 AM
Thanks for the feedback - very useful tips in here. I'm going to give it another shot.
HTML code is On
plosive removal sound arts Post - Surround - Video 9 11-25-2005 02:32 AM
