Error Message on PT8 Install & PLAY Install
Has anyone seen these messages before? It first happened when I was installing PT8 and then again when I was installing EastWest Pianos (PLAY).
Both of these products seem to be working fine even though I got this error. "The driver package is not signed. ocurred in .\CopyInf.cpp at line number:397 Other Error:-2146762496 Internal Operation :200" I am unable to find any reference to this using the search function. Cheers, Andrew
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+ Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9 |
Re: Error Message on PT8 Install & PLAY Install
Here is my Sandra...
SiSoftware Sandra Computer Model : System manufacturer P5Q Workgroup : PHUQER Host Name : xp-audio User : Administrator Processor Model : Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Speed : 2.33GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : Asus P5Q BIOS : AMI 1611 11/26/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR2 DDR3 Chipset Model : ASUS P45/P43/G45/G43 DRAM Controller Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Mushkin 991599 996599 2GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-18 3-23-6-3) Memory Module : Mushkin 991599 996599 2GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-18 3-23-6-3) Video System Video Adapter : NVIDIA GeForce 9600 GT (64 SP 1.65GHz, 512MB DDR3 2x900MHz, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce 9600 GT (64 SP 1.65GHz, 512MB DDR3 2x900MHz, PCIe 2.00 x16) Graphics Processor Storage Devices WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (C:) (D:) (G:) WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (F:) ST3250620A (250GB, FireWire/1394, 3.5", NCQ) : 233GB (K:) ST3500630A (500.1GB, USB/ATA100, 3.5", 16MB Cache) : 466GB (H:) (I:) HL-DT-STDVD-RAM GH22NS30 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (E:) Logical Storage Devices GENERAL OS (C:) : 39GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) AUDIO OS (D:) : 39GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) BACKUP (G:) : 388GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) PROJECTS (F:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Hard Disk (K:) : 233GB (NTFS) @ ST3250620A (250GB, FireWire/1394, 3.5", NCQ) QL Pianos Disc 1 (E:) : 7GB (CDFS) @ HL-DT-STDVD-RAM GH22NS30 (SATA150, DVD+-RW, CD-RW, 2MB Cache) Storage3 (H:) : 195GB (NTFS) @ ST3500630A (500.1GB, USB/ATA100, 3.5", 16MB Cache) Storage4 (I:) : 270GB (NTFS) @ ST3500630A (500.1GB, USB/ATA100, 3.5", 16MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13h Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Serial Port(s) : 1 Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS 6121 SATA2 Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : Adaptec FW322/323 IEEE1394 OHCI FireWire Controller FireWire/1394 Controller 2 : ASUS IEEE 1394a Firewire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - Packet Scheduler Miniport (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86
I have the same error when install 8.0.1 update during the installation and then cs1 at the end of install process.
Interesting how it affect on PT work... hope it not :) |
Yep, I get that same error too, after which everything else seems ok.
I suspect it's more likely Windows related than PLAY related. I'm watching it like a hawk though..... .
"Well, of course, their requests for subsidies was not Paraguayan in and of it is as it were the United States government would never have if the president, our president, had not and as far as I know thats the way it will always be. Is that clear?"- Chevy Chase, Spies Like Us. |
I had the same error today - while updating to 8.0.1. PT seems to work OK, however.
Does anyone have any thoughts on what the problem is - or, how to resolve it? |
Weird error message after initial install... | Save|The|Architect | macOS | 4 | 01-17-2012 04:54 AM |
Error Message When I Install PT8LE on W7 | Cate1 | Tips & Tricks | 2 | 01-10-2012 05:39 AM |
Error Message on Install of PT 8.0.3 on W7 | Cate1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-08-2012 06:48 PM |
Windows XP Logo not checked message upon install | jbcampo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-20-2008 07:28 AM |
Message: "hardware not connected" new install | DigiDave001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-12-2005 10:44 AM |
