Old 10-28-2014, 12:23 AM
7headed 7headed is offline
Default Insert Time/Change Tempo
I inserted time in the middle of a song. The section prior to the insert is at 120 BPM. The section after the insert is also 120 BPM. I want the middle section of time I inserted to be a different tempo; in this case it's 45 BPM.
Here's my problem: when I change this middle section to the new tempo, all the subsequent tempos in the rest of the song are pushed farther down to different bars, even though I check "preserve tempo after selection".
What do I do to keep the other tempos I've set to stay in their place after changing a middle section? Thank you.
Old 10-28-2014, 06:04 AM
GregV GregV is offline
Default Re: Insert Time/Change Tempo
I believe you need to be in Shuffle Mode (top left corner of the Edit window) when you insert the new bars
Old 10-28-2014, 09:00 AM
I can insert new time without a problem. It's when I try to change the tempo in those new bars that moves all other tempos after them. I'll try the shuffle mode just to see if it makes a difference. Thank you.
Old 10-28-2014, 08:01 PM
I think I may have solved the problem. All of my tracks were "sample" tracks. When they were samples, the tempos and tracks would not line up when I made a tempo change. When I changed them to "ticks", all the tempos moved with the tracks equally.
Elastic time wont let me change the tempo veryphresh macOS 1 01-28-2011 08:33 PM
help! insert the tempo/meter change in the session iamjungle Pro Tools TDM Systems (Mac) 13 04-26-2010 10:20 AM
BDF insert - can't change tempo habernacks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-27-2006 11:52 AM
Time Shift to change tempo??? delwin Pro Tools TDM Systems (Win) 2 08-23-2006 11:39 PM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
