Old 09-21-2022, 03:21 PM
senghor senghor is offline
Default How to backup PT sessions
How to backup correctly PT sessions ie. from a sdd to hdd? Are You using a proper program to do that?
I have just copy/paste my sessions and I know one day I will have corrupt files.
Thanks.
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 09-21-2022, 03:36 PM
Philthy Philthy is offline
Default Re: How to backup PT sessions
20 years I've been doing it like you describe on Mac... I just drag across at the end of each day. No corruption yet. I've had drives die but that's unavoidable... I keep minimum 2 copies until a project is complete.
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 09-21-2022, 03:52 PM
How you do it is one thing.
You also need to think about practice recovering sessions... ideally test on a different computer so that things like content files not included in the session folder are detected.
There are many options, you can drag and drop folders, or write a script that zips them up, adds a date to the zip file name, etc. simple scripts can be great... as long as you test periodically. And what happens when the target drive is full? Or the same name file exists on the drive, or there is some error.. same for commercial backup software... know where the error log is and check it periodically.
And then just backing up to one HDD may not be enough, how many separate HDD copies? where are they kept? How many off-site? What about copies to cloud storage as well.
And that's Pro Tools sessions? What happens when the boot drive fails or is corrupted? How do you recover the boot drive?
Also how do you save finished projects, the exported/bounced files or stems, make sure they are backed up as well.
The right approach is not always to just make new backups over old, you may need to roll back in time, in which case things like zipped folders with a date in the name are handy.
Old 09-22-2022, 01:49 AM
danyg danyg is offline
i use the software CCC. Set and forget...
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 09-22-2022, 01:55 AM
thin ice thin ice is offline
I run Time Machine at the end of each working day and also a weekly copy & paste backup of sessions.
The more important thing is to use "save copy in" as a backup when you are done and keep three copies, hopefully one off site. Just copy & paste leaves you open to not gathering any files that may be in the wrong directory. This can happen when someone sends you a session to mix.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 09-22-2022, 09:46 AM
The Weed's Avatar
The Weed The Weed is offline
Zip to OneDrive, copy/paste, image my Audio Drive Nightly with Macrium Reflect and, when necessary, copy to my Storage Drive and burn a data DVD.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-22-2022, 11:10 AM
Southsidemusic's Avatar
+100
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-22-2022, 11:21 AM
Ben Jenssen's Avatar
+me
But Carbon Copy Cloner is mac only, sadly.
And the OP is on windows.
Old 09-22-2022, 11:34 AM
cwsand's Avatar
cwsand cwsand is offline
I backup to cloud storage, manually backup to external hard drives, burn sessions to BluRay and use Time Machine. You can never have too many backups!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 09-22-2022, 02:46 PM
resonatee resonatee is offline
Originally Posted by senghor View Post
All of the above. Also,
This video shows how : https://www.youtube.com/watch?v=--8nj43kgyg
Safest way to Backup sessions? ian Bourgal Storage Subsystems 4 01-17-2015 11:02 AM
Best way to backup PT sessions? chieflh General Discussion 7 03-21-2010 04:14 AM
What to Backup PT sessions to? mahjorbidet Pro Tools TDM Systems (Mac) 10 09-04-2003 12:48 PM
How do you backup your golden sessions? DigiG4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-10-2003 01:29 AM
backup of sessions from a Mac, copied on a PC... jeronimo General Discussion 0 08-07-2001 06:35 PM
