RAM Timings
Does anyone know what manual memory timings I can try based on my RAM and Processor? The Sandra Report is listed below. It's something I'd like to try but don't want to risk inputting wrong settings. I've tried many forums and the manufacturers website has limited info regarding this. I'd really appreciate some help on this. Specifics would be great. Thanks in advance
Pro Tools v9.0.3 Digi 002 (with latest drivers installed at the time of this post) 2 x UAD 1 Accelerator Cards UAD v5.9.1 software (latest software installed at the time of this post) SiSoftware Sandra Processor Model : Intel(R) Core(TM) i5-2300 CPU @ 2.80GHz Speed : 3.1GHz Cores per Processor : 4 Unit(s) Type : Quad-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : ASUS P8P67 LE BIOS : AMI (OEM) 1003 02/11/2011 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DIMM DDR3 Chipset Model : ASUS Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Corsair CMV4GX3M1A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMV4GX3M1A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 8400 GS (Microsoft Corporation - WDDM v1.1) (8 SM4.0 1.4GHz, 512MB DDR2 704MHz 64-bit, PCIe 2.00 x16) Graphics Processor Storage Devices Seagate ST31000524AS (1TB, SATA600, 3.5", 7200rpm) : 932GB (C:) SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices System Reserved : 100MB (NTFS) DATA-II (D:) : 932GB (NTFS) @ SAMSUNG HD103SJ (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Hard Disk (C:) : 931GB (NTFS) @ Seagate ST31000524AS (1TB, SATA600, 3.5", 7200rpm) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS Cougar Point LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASUS Cougar Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Serial Port(s) : 1 Disk Controller : ASUS Cougar Point 6 port SATA AHCI Controller Disk Controller : ASUS 88SE91A0 SATA-600 Controller Disk Controller : Marvell 88SE91A4 SATA-600 Controller USB Controller 1 : ASUS Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : ASUS Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : ASUS ASMedia XHCI Controller FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : NETGEAR WNA1100 Wireless-N 150 USB Adapter (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Re: RAM Timings
9-9-9-24 are the numbers you should use(but double-check with the RAM manufacturer and make sure those are correct for your exact RAM sticks). Refer to the motherboard manual for info on how to set those in BIOS. Also, make sure(if you have 4 slots for RAM) that you are using the correct pair of slots for 2 sticks(or your dual-channel RAM may not operate correctly).
Re: RAM Timings
What I'm finding unacceptable is the "glitch" I'm getting when I hit record. It's really annoying and I shouldn't need to apologise to my clients every 5 minutes for this. This glitch happens regardless of whether I use the control surface transport or the GUI transport. It happens with both Quick Punch and Pre Roll mode. I've been using Pro Tools since v6 and every other version/update/patch up to and including v8 on far lesser machines and have never had this issue. Not sure if anyone else is having this problem but I'd sure like to know. But again, I really appreciate the advice from fellow forum members. I reckon Avid have a hide like a rhino charging for tech support. |
Re: RAM Timings
make sure you do not have 'use all available space' checked in your prefs...that could result in hesitation/glitch at the start of playback. set it to cover your session time...10 mins or whatever your number may be. also PT9 has a bug that causes pops/clicks when usin' quick punch...regardless of how you implement it...pre-roll/post-roll or not.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Re: RAM Timings
Re: RAM Timings
cool...don't forget to delete your databases when makin' the changes
Re: RAM Timings
Yep. Many of us have been putting up with the punch-pops bug ever since upgrading to 9. Nothing for it but to put up with it until it gets fixed.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
help setting up ram timings please | Raoul23 | Pro Tools 10 | 7 | 05-31-2012 06:36 AM |
Exporting timings from track | ysiddiqui | Pro Tools 10 | 0 | 04-02-2012 04:29 PM |
RAM timings | sw rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 12-31-2009 01:57 PM |
Visual Countown for ADR/VO timings for talent? | masterboyle | Post - Surround - Video | 4 | 08-03-2009 02:39 PM |
Need advice ASAP re: shifting timings in a film project | ckpmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-16-2007 07:31 AM |
