Strike Question
I can't seem to get my head around this? I have a General Midi drum track and I want it to trigger the appropriate elements in a Strike kit. I've created a stereo Instrument track and put Strike on it, then loaded a kit? Then I assigned the Midi Drum Track's output to a Strike Midi Channel. I thought I read somewhere that for GM you need to assign to Strike CH2 but it doesn't seem to work. None of the Midi channel assignments from the Midi Drum Track seem to trigger the appropriate samples on the Strike Drum Kits? I must be missing the boat on this? Are the strike samples mapped as per GM? If not, what is the workaround. Any help?
Re: Strike Question
Any particular reason you're not just programming the midi on the instrument track?
----I was thinking of taking a solo in the bridge. -Nah, I don't think that would sound good. ----Ok, well how about just a series of cool riffs? Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK |
Re: Strike Question
No particular reason ... I just have a GM file playing though a GM module and I wanted use Strike to play the Midi Drum Track instead of using the module. I am sure I have done this before but for some reason I can't seem to get it working now. So in essence I want to use Strike as a GM sample player triggered by a pre-programmed GM midi drum tk.
Re: Strike Question
http://airvirtualinstruments.blogspo...h/label/strike
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Re: Strike Question
Thanks Russ ..... turns out I was doing it right .... Midi GM Drum Track output assigned to Strike CH2 does play mostly accurately .. some adjustments need to be made in some cases but easy to do.
Re: Strike Question
filosofem |
Strike and vst question | trajan24 | macOS | 3 | 03-13-2012 10:58 PM |
Strike question | sundaze | Virtual Instruments | 2 | 02-27-2010 02:53 AM |
Another Strike Question... | StinkyStan | Virtual Instruments | 1 | 05-11-2009 10:39 AM |
Strike question | oulablank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-01-2008 12:51 PM |
strike question | sykobilly65 | Virtual Instruments | 3 | 02-27-2008 09:59 AM |
