Old 11-18-2008, 03:27 PM
DHiggins DHiggins is offline
Default VSS3 conflicts
I'm having conflicts with TC electronics VSS3 and now possibly Surcode PLII rtas plugin.
One major symptom is that I can't change the amount of voices and/or number of processors within a session. Prior to fixing permissions on individual plugin and folders, a session wouldn't launch if it had the VSS3 plugin in it. However I could get very small 2 or 3 track sessions with VSS3 to launch successfully.
Upon session relaunch, it freezes in the middle of the launch...usually on the one or two of the same track names.
I thought we had narrowed this down to a permissions issue, but apparently not. We've been through the normal repair permissions, throw away prefs, etc a million times. Double checked the plugin compatibility grid. Do not have any waves plugins on this computer.
After having a workable solution as long as I didn't change system voice or rtas processor settings, everything was fine.....until I installed Surcode. I then relaunched a session and it would hang (as it did in regards to VSS3)
Any ideas on this???
thanks
PT 7.4.2
OS Leopard 10.5.4
4GB factory ram
HD3 Accel
Old 11-18-2008, 03:45 PM
Eric Lambert's Avatar
Default Re: VSS3 conflicts
Does Surcode have to be open for the problem to occur? Do Surcode AND VSS3 both have to be open for the problem to occur?
Which version of ProTools (any of the CS updates)?
Old 11-19-2008, 08:01 AM
DigiTechSupt's Avatar
Also, have you made sure ALL installed plug-ins are updated?
Pro Tools Leopard Plug-in Updates
Having just one incompatible plug-in in your plug-ins folder, even if it's not used in the session, can cause all kinds of strange behavior in Pro Tools.
Avid Audio Tech Support
Support FAQ
Old 11-19-2008, 09:55 AM
I am double checking all plugins.
I am also just coming from a very rock solid identical set up on a intel 2.66 hd2 accel with all of the same plugins working just fine. The variables are new accel cards (hd3) and 8 core mac. with a couple hd3pack plugins added
Old 11-19-2008, 10:34 AM
25ghosts 25ghosts is offline
Originally Posted by DHiggins View Post
I'm having conflicts with TC electronics VSS3 and now possibly Surcode PLII rtas plugin. snip....
Maybe this is a lame suggestion but try this:
Move all plugs - except the VSS3, Stereo Mixer and Surcode into the unused plug-folder.
Then launch the session in question. See what happens
If the problem still persist try removing VSS3 if the problem is gone - swap VSS3 and Surcode - make notes of what happens.
If the session works fine with either activated alone - then at least you know where the problem could be.
This is what I always way when I get a hunch that some kind of plug is acting like a fool
Good Luck
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 11-19-2008, 10:57 AM
Does anyone have a 1.2.2 version of VSS3?
the only version the tc site has is 1.2.3
the digi compatibility only says 1.2.2
upon pressing apple "I" on the plugin itself is says 1.2.3.xxx (forget what these numbers were) beta
tc support doesn't seem promising. I tried calling ed at the westlake office and can't get through...and sent through support email.
thanks
Old 11-19-2008, 01:38 PM
Our compatibility info is the minimum version required - so if you have 1.2.3, you're technically good to go.
Support FAQ
Old 11-19-2008, 04:38 PM
Thanks everyone,
still no real success. Checked the current plugin list and took those not listed (surrcode) out of the equation to test, didn't make a difference...
TC is ultimately the problem.
currently 1.2.3 trying to revert to 1.2.2 and still can't get something from TC. Digi, i know you say 1.2.3 should be fine, but in the info the word BETA is there....
-increasing my chip/voice count. I can't change my existing 1 chip 48 voice session to 3chips 96 voices without hanging up on session re-open. I opened a fresh session with 96voice count and tried to "import session data" all tracks...and it hung up. I was able to run a 2chip 96 session (and am doing that now)
Old 11-19-2008, 11:31 PM
Old 11-19-2008, 11:48 PM
JFreak's Avatar
JFreak JFreak is offline
You shoud be using 1.2.3 which is the latest version available. Previous version had a strange bug: if you instantiated two VSS reverbs and they shared the same chip, the audio output went crazy. But one plug works perfectly.
Janne
Help with a VSS3 preset? scottwilson RTAS & TDM Plug-ins 4 01-22-2021 09:33 AM
TC VSS3 Fixed on PT8 dr sound Post - Surround - Video 0 02-09-2009 08:25 AM
Tc vss3 K.I. Pro Tools TDM Systems (Mac) 1 02-09-2009 06:09 AM
TC Electronis VSS3 TCLguy1 Pro Tools TDM Systems (Mac) 11 03-13-2007 01:19 AM
Anyone using TC Electronic MD3 or VSS3 with PT7 HD guitar012001 Pro Tools TDM Systems (Mac) 2 10-03-2006 12:13 AM
