7.3 icon bounces and won\'t startup! Please help.
Hello,
I just upgraded to 7.3, did the uninstall and installed 7.3. When I try to open up a session or Pro Tools, the icon bounces on the dock for about a minute and then quits even before showing the HD 7 splash screen. I have even tried uninstalling again and installing. Can anyone help me out? Thanks!
------------------------- OSX 10.5.8 Pro Tools 8.0 HD MAC PRO Dual 3.2GHz Quad- Core 8 GB RAM EXTERNAL OWC FIREWIRE 800 Drives 2 x Digi 192 i/o 24 ins 24 outs |
Re: 7.3 icon bounces and won\'t startup! Please help.
Can you give more details!! what version did you upgrade from? which mac do you have and OS do you have? Have you checked the 7.3 auth is on your ilok and your ilok is connected ok?? how much ram fitted? is the Digi hardware connected ok and turned on?? as many details as you can!!! Chris
Sorry bout that.
I upgraded from 6.9 I'm on G5 dual 2.0 2GB of ram 10.4.8 OS The auth is on the iLok Everything seems to be connected fine. I was opening 6.9 files just fine before I upgraded. Now I am regretting upgrading and spending the $200
Out of pure frustration and deadlines I decided to format my HD and do a clean install of OS and 7.3. Seems to be working fine now. I hope it doesn't happen again!
Just out of interest, when you updated your Mac OS to 10.4.8 did you do the incrimental update or did you use the combo updater? its been recommended to use the combo updater!! P.S. I would get some more ram for tiger and 7.3? 2 gig was fine for panther but tiger seems to be a ram hog, i'm using 5.5 gig now and it runs sweet. Chris
I did the combo updater. SO far so good .
Thanks for the tip on the RAM, I might have to give that a shot
This just happened to me again
Any tips other than formatting again??
delete all the pref and digibase files
run permissions repair from disk utility double check file access permissions on the app
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Thanks for the reply. I tried all of that and still no luck.
Here Hope that helps, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
PT Icon Bounces, Stops for a few minutes, Then Loads. | TeardropCarnival | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-18-2009 10:21 PM |
Pro Tools LE icon just bounces....no launch | PhilyG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2007 01:41 PM |
Protools Icon bounces in dock but program won't start | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-25-2007 08:24 AM |
new macpro trouble Protools won't start--icon bounces..... | macprojoe | Pro Tools TDM Systems (Mac) | 17 | 03-19-2007 04:46 PM |
mac startup ? can't find startup disc | peterfitz | Pro Tools TDM Systems (Mac) | 1 | 03-24-2000 08:27 AM |
