Old 08-16-2006, 12:08 AM
kalos kalos is offline
Default no monitoring while recording
the last few days i have been ready for a voice over session running through an avalon preamp into the 002 and then the c24. im using the c24 main control room monitoring section to monitor and using the aux outs for a headphone amp for the announcer. but when i go to record there is no monitoring in my studio or for the announcer in his cans, but yet it still records onto the track in pro tools. then i can stop and play it back. its doing my head in
i have tried doing sys resets on the c24 and so on but no luck. it randomly just works when it wants??
anyone heard of this or expirienced it?? any ideas. could it be anything im doing wrong or does it sound like a prob with the c24?
Old 08-16-2006, 01:08 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: no monitoring while recording
So if you have any pre recorded audio in the session, does this get muted as well? or is it only the audio you are recording that gets muted?
If you disable the c24 and don't use it!! can you still go into record and hear the outputs from your 002? i've no experience with 002 so i don't know exactly how the monitoring works, but this test should tell you if its a Pro tools Le/002 setting or whether its the C24.
I doubt the C24 has a fault! i can't think why the sound would mute during record from the C24. on TDM we have diffrent fader settings for playback and record! but thats TDM.
Some 002 users will pop bye soon and hopefully advise.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-16-2006, 01:45 AM
if there is sound on the timeline in le it plays trough the monitors and in the cans. its only the audio while recording that disappers. i tried coming out of the oo2 rack main outputs/ monitor outs into the speakers but still the same problem? so id assume its the c24? its got me stumped!
Old 08-17-2006, 12:58 AM
crizdee's Avatar
If you're hearing previously recorded audio ok then its not the c24! but more likely to be a setting in LE! LE and the 002 works different to TDM so i have little experience in that area. But have you checked all the preferences settings that are related to monitoring?
When recording can you hear anything from the heradphone out on the 002?
Have you reset the C24?
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-20-2006, 07:00 PM
yeh all the prefs seem fine, i tryed to monitor with the headphone through the 002 rack whilst recording but still no luck. does it sound more like a fault with the 002 itself. i have reseted the c24 and that doesnt work.
Old 08-21-2006, 05:50 PM
i have just been playing with my settings and i flicked the low latencey monitoring off and i could monitor then flicked it back on and the monitoring died completley? and so on. im glad it doesnt look like a c24 problem.
Old 09-02-2006, 12:51 PM
espron espron is offline
Are you using sends to monitor the VO talent? If so, I can tell you that enabling low latency monitoring in PTLE bypasses all sends and only allows you to monitor tracks assigned directly to out 1-2.
If you want to use sends, (as I imagine you do) you will have to turn low latency monitoring OFF, and see if one of the lower buffer settings will be acceptable to your VO talent. Most of the time, a buffer size of 128 samples seems acceptable in my experience.
All the best
Espen
IMDB
Monitoring When Recording? asimmd Pro Tools M-Powered (Win) 2 10-21-2011 07:18 AM
Monitoring recording with a 002 in DP 4.6 Digidiot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-02-2005 01:11 AM
Q: Monitoring & Recording in Logic with 001 microDAT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-18-2003 09:06 AM
monitoring w/out recording... stickydunkel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-10-2001 08:26 PM
monitoring/recording set up pug 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-02-2000 10:35 AM
