Old 12-07-2010, 03:45 PM
allegrarc allegrarc is offline
Default The current playback engine does not support a sample rate of 48 kHz.
My Digi003 recently died, just in time for PT9. I bought the upgrade and purchased a Focusrite Liquid Saffire 56. I did all the installations as instructed. However, I keep getting the following message: The current playback engine does not support a sample rate of 48 kHz.
Old 12-07-2010, 07:49 PM
lincol1 lincol1 is offline
Default Re: The current playback engine does not support a sample rate of 48 kHz.
That's correct...lowest buffer on a 3rd party interface is 64.
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 12-07-2010, 08:05 PM
necjamc necjamc is offline
He's talking sample rates, not buffer size.
I get this error every now and then. Sometimes because something else (ie Youtube) is using the interface before I open PT, and other times I have to power cycle my interface and PT to get it to show up right. Unsure why this is though.
Old 12-07-2010, 08:12 PM
Oops...need to put on the glasses...
Lincoln Mitchell
www.studiofifty.net
Old 12-07-2010, 08:23 PM
Old 12-09-2010, 09:04 AM
cshaw cshaw is offline
This seems to be a problem when you use your interface to play back your Mac audio. PT and your Mac are trying to access the same interface and usually the Mac wins. Try switching your Mac to Internal Speakers in the system prefs and start up PT9 afterwards.
I find that if I use my interface to play back the computer audio that PT seems quieter. Then I realized that the computer was controlling the volume of the interface. Raising the computer volume fixes this, but it's a better practice to set the computer audio to internal speakers before starting PT.
Old 01-07-2011, 10:52 PM
joshrosario310 joshrosario310 is offline
Thank you cshaw, I didn't even think to check the Mac audio! I just downloaded PT9 and have a bed session tomorrow morning so I rented a Presonus Firestudio which I couldn't get to open sessions until now.
Old 08-17-2012, 10:07 AM
RichrdC RichrdC is offline
Could this playback engine not supporting sample rates have anything to do with the Main Outputs being set to something other than 1-2?
Old 01-28-2014, 04:58 PM
davidraven davidraven is offline
i've had this problem intermittently with pt 10 and 11 on a mac pro. just solved it for me. in the pro tools menu>setup>playback engine: it was set to airplay, switched it to apollo, which is my interface, all good now. i was using airplay to stream audio to other parts of my home/studio, and somehow the playback engine got switched to airplay.
hope that helps.
raven
Old 11-27-2014, 09:43 PM
guitarman6 guitarman6 is offline
THANK YOU. Just had weird issue installing 11 on new machine that had 10.3.4 on it and this popped up.
SETUP > PLAYBACK ENGINE > changing playback engine to "Built-In Output" changed it all on both platforms.
Cheers!
MBP M1 Max | 64 GB | 4TB | macOS Monterey Version 12.7.4
[Legacy] Mobile: MBP Retina 2.6 HGz Intel Core i7 w 16 GB 1600 MHz DDR3 running macOS Catalina (10.15.7) w/ Pro Tools Ultimate 2020.12
[Legacy System] Studio: Mac Pro 2 x 2.93 GHz Quad-Core Intel Xeon w 16 GB 1066 MHz DDR3 RAM running OS X 10.8.5 using Pro Tools v10.3.9 & v11.3.2 HDX w/ AVID HD I/O
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The Current Playback Engine Does Not Support A Sample Rate of 44.1Khz ZiviMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-29-2013 02:05 PM
The current playback engine does not support a sample rate of 192k Oblivious74 macOS 3 06-01-2011 07:08 PM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
